Natural and step response RLC find iL(t)
In summary, the circuit in the figure has a switch that has been open for a long time before closing at t=0. The problem asks for the function iL(t) for t>0, expressed in terms of t in milliseconds. The simplified circuit consists of a 4A current, 2kohms, 62.5H, and 2.5uF in parallel. The solution involves finding the values of iL at t=0 and t=∞, and using these values to solve for the coefficients in the equation iL=4-12e^-40t+3e^-160t for t≥0.
pokie_panda
37
The switch in the circuit in the figure has been open a long time before closing at t=0.
Find iL(t) t>0
Express your answer in terms of t, where t is in milliseconds.
https://www.flickr.com/photos/84781786@N03/8899251427/
We simplify to circuit to get
4A current , 2kohms,62.5H,2.5uF (All in parallel with each other).
iL(0-)= -15/3000 =-5mA ,
Vc(0-)=0,
iL(∞)= 4mA,
wo^2= 1/LC=10^6/62.5*.5 =6400
wo=80 rad/s
a= 1/2RC =10^6/4000*2.5 =100
s1,s2=-100±√100^2-80^2=-100±60
s1=-40 , s2=-160
iL=If+A'1e^-40t + A'2e^-160t
iL(∞)=If=4mA
iL(0)=A'1+A'2+If=-5mA
so A'1+A'2=-9mA
diL/dt(0) =0=-40A1 - 160A'2
A'1=12mA A'2=3mA
iL=4-12e^-40t+3e^-160t t≥0
Your diagram doesn't appear to match your problem statement.
What switch?
Related to Natural and step response RLC find iL(t)
1. What is the difference between natural and step response in an RLC circuit?
The natural response of an RLC circuit is the behavior of the current or voltage in the circuit due to the initial energy stored in the inductor or capacitor. The step response, on the other hand, is the behavior of the current or voltage in the circuit due to a sudden change in the input voltage or current.
2. How do you find the natural response in an RLC circuit?
To find the natural response in an RLC circuit, you need to solve the differential equation that describes the circuit using techniques such as Laplace transforms or differential equations. The resulting solution will give you the behavior of the current or voltage over time.
3. What factors affect the natural response in an RLC circuit?
The natural response in an RLC circuit is affected by the values of the inductance, capacitance, and resistance in the circuit. It is also influenced by the initial conditions, such as the initial current or voltage in the circuit.
4. How do you find the step response in an RLC circuit?
To find the step response in an RLC circuit, you need to apply a step input to the circuit and then solve the differential equation that describes the circuit. The resulting solution will give you the behavior of the current or voltage over time after the step input.
5. What is the significance of the natural and step response in an RLC circuit?
The natural and step response in an RLC circuit provide important information about the behavior of the current or voltage in the circuit. They can be used to analyze the stability of the circuit, determine the resonant frequency, and design filters for specific applications.
