Natural frequency of a simple harmonic system
In summary, the natural frequency of a system composed of two homogeneous circular cylinders and a connecting link of mass m can be derived using the sum of kinetic and potential energies. The equation of motion for an undamped, simple harmonic system is used, and small angle approximation is applied. The correct answer can be obtained by ensuring that the velocities of the link and the cylinders are calculated with respect to the same frame of reference, such as the ground.
TomW17
Derive the natural frequency [itex]f_n[/itex] of the system composed of two homogeneous circular cylinders, each of mass [itex]M[/itex], and the connecting link [itex]\text{AB}[/itex] of mass [itex]m[/itex]. Assume small oscillations.
The sum of the kinetic + potential energies in an isolated system remains constant.
An undamped, simple harmonic system has an equation of motion of the form [tex]\ddot{\theta} + \omega^{2}_n \theta = 0[/tex]
The sum of the kinetic + potential energy when the system rotates by an angle [itex]\theta[/itex] measured as in the diagram counterclockwise is [tex]\sum E = V + T = mg r_0 (1 - \cos \theta ) + \tfrac{1}{2} m v_{AB}^{2} + 2 \times \tfrac{1}{2} M v_{O}^2 + 2 \times \tfrac{1}{2} I_O \dot{\theta}^2 = \text{const.}[/tex]
where [itex]v_O[/itex] denotes the velocity of the centre of mass of the cylinders, [itex]\dot{\theta}[/itex] denotes the angular velocity of the system (and by extension the angular velocity of the cylinders) and [itex]v_{AB}[/itex] the velocity of the centre of mass of [itex]\text{AB}[/itex].
[tex]E = mgr_0 (1 - \cos \theta ) + \tfrac{1}{2} m (r_0 \dot{\theta})^2 + M (r \dot{\theta})^2 + \tfrac{1}{2} M r^2 \dot{\theta}^2 = \text{const.}[/tex]
[tex]\implies \frac{\text{d}E}{\text{d}t} = mg r_0 \sin \theta \dot{\theta} + m r^{2}_0 \dot{\theta} \ddot{\theta} + 3 Mr^2 \dot{\theta} \ddot{\theta} = 0[/tex]
using small angle approximation and rearranging...
[tex]\ddot{\theta} + \frac{mgr_0}{3Mr^2 + mr^{2}_0} \theta = 0 \implies \omega_n = \sqrt{\frac{mgr_0}{3Mr^2 + mr^{2}_0}} \implies f_n = \frac{1}{2\pi} \omega_n[/tex]
The answer given in the book is [tex]f_n = \frac{1}{2\pi} \sqrt{\frac{mgr_0}{3Mr^2 + m(r-r_0)^{2}}}[/tex]
Comparing the answers, my problem appears to be that I've calculated the kinetic energy of the link [itex]\text{AB}[/itex] incorrectly but I can't figure out why. My logic was that the angle [itex]\theta[/itex] is the angle between the vertical through the centre of the cylinder and the line connecting the centre of the cylinder and the end of the link [itex]\text{AB}[/itex], so the velocity of the end of [itex]\text{AB}[/itex] would be equal to [itex]\dot{\theta} r_0[/itex] (angular velocity x arm) and as [itex]\text{AB}[/itex] remains horizontal throughout, the velocity of the centre of mass of [itex]\text{AB}[/itex] would be the same as the velocity of its end.
Help?
You could put in a few more steps to help a tired old duffer understand how you get each thing.
It looks like you have ##v_{AB}## as ##r_0 \dot{\theta}##, and ##V_O## as ##r \dot{\theta}##. But you need to be sure that these are both in the same frame of reference. Are these both with respect to the ground?
Likes TomW17
Ahaa, there's my problem. No, I've calculated [itex]v_{AB}[/itex] to be wrt the centre of the cylinder but [itex]v_O[/itex] is wrt the ground.
Got the right answer when I take ##v_{AB}## wrt the ground. Thanks for your help!
Likes DEvens
Related to Natural frequency of a simple harmonic system
1. What is the definition of natural frequency in a simple harmonic system?
The natural frequency of a simple harmonic system refers to the frequency at which the system will oscillate without any external force acting on it. It is determined by the mass and stiffness of the system and is independent of the amplitude of the oscillation.
2. How is the natural frequency of a simple harmonic system calculated?
The natural frequency of a simple harmonic system can be calculated using the equation f = 1/(2π√(m/k)), where f is the natural frequency, m is the mass of the system, and k is the spring constant or stiffness of the system.
3. What factors affect the natural frequency of a simple harmonic system?
The natural frequency of a simple harmonic system is affected by the mass and stiffness of the system. A higher mass or a stiffer spring will result in a lower natural frequency, while a lower mass or a less stiff spring will result in a higher natural frequency.
4. How does the natural frequency of a simple harmonic system relate to its period and frequency of oscillation?
The natural frequency of a simple harmonic system is directly related to its period and frequency of oscillation. The period of oscillation is equal to 1/f, where f is the natural frequency, and the frequency of oscillation is equal to f.
5. Can the natural frequency of a simple harmonic system be changed?
Yes, the natural frequency of a simple harmonic system can be changed by altering the mass or stiffness of the system. It can also be changed by introducing an external force, which will affect the frequency of oscillation but not the natural frequency of the system.
