Natural numbers form a poset under $ \le$
In summary, the problem is asking for a way to show that $(\mathbb{N},~\le)$ is a poset under the ordinary order, but the solution is trivial.
QuestForInsight
34
Problem: let $\mathbb{N} = \left\{0, ~ 1, ...\right\}$ be the set of natural numbers. Prove that $(\mathbb{N},~\le)$ is a poset under the ordinary order.
Solution: let $x \in\mathbb{N}$, then $x \le x$ as of course $x = x$. If also $y \in\mathbb{N}$, then $x \le y$ and $y \le x$ implies $x = y$. Lastly, $x \le y$ and $y \le z$ implies $x \le z$. Therefore $(\mathbb{N}, ~ \le)$ is a poset under the ordinary order.
Is the above valid? I feel like I'm basically stating what I was asked to prove!
I think your conscience could be eased if you try to justify using euclidean division: if $x \leq x$ then we have that $x = qx+r$ with unique $q,r$. This is true if and only if $q=1$ and $r=0$.
If $x \leq y$ and $y \leq x$ then we have $x = q_1 y + r_1$ and $y = q_2 x + r_2$. It follows that $y = q_2 (q_1 y + r_1) + r_2 = qy + r$, which by previous arguments leads to $q=1$ and $r=0$, but then $r=r_2 + q_2 r_1 = 0$ and $q=q_2 q_1 = 1$, concluding that $q_1 = q_2 = 1$ and $r_1 = r_2 = 0$.
I believe the last one can be done in a similar way. I hope this helps. (Nod)
And what does this prove?
It seemed a more confident way to prove the assertions, but I confess it does seem tautological.
By saying "If x <= x", you assume x <= x instead of proving it. And in any case x = x and x <= x <-> x = x \/ x < x are axioms or easily derivable statements in most systems, so proving x <= x using Euclidean division is definitely more complicated than necessary. Proving antisymmetry using Euclidean division may make sense, though the first thing that comes to my mind is to express <= through < and = and use transitivity an irreflexivity of < .
As an answer to the original question, this statement is definitely trivial and I think the suggested "argument" is fine. Unless one has to prove this using specific axioms in a specific formalism, there is not much more here than to look at it and say, "Yes, this is trivial."
i think the crucial thing here is that:
x ≤ y
is actually:
(x = y) v (x < y).
so if you wanted to get nit-picky about it, you'd have to consider the various cases.
for example, suppose x ≤ y, and y ≤ z.
if x = y, then x ≤ z.
if x < y, and y = z, then x < z (= y), so x ≤ z.
else, if x < y < z, then x < z, so x ≤ z.
of course, perhaps you are meant to delve deeper:
what do we MEAN when we say: x < y, for 2 natural numbers x and y?.
we mean that y is "bigger" than x. that is, we are asserting there is a natural number k ≠ 0, with x+k = y.
so x < y, and y < z means:
there is k ≠ 0 with y = x+k, and m ≠ 0 with z = y+m.
thus z = y+m = (x+k)+m = x+(k+m).
now, to be thorough, we should verify k+m ≠ 0.
since m ≠ 0, m = s(t), for some natural number t (by definition of successor).
thus k+m = k+s(t) = s(k+t), by definition of addition on the natural numbers.
since 0 is not the successor of any natural number, k+m ≠ 0.
more generally, given any TOTAL order < on a set S, (S,≤) is a poset. in some sense these posets are "trivial": their hasse diagrams are linear. in other words, not very interesting (but not unimportant).
with questions concerning the natural numbers, it's perhaps a good question for your instructor: "what properties of $\Bbb N$ can we take as 'obvious'?"
FAQ: Natural numbers form a poset under $ \le$
What are natural numbers?
Natural numbers, also called counting numbers, are a set of positive integers starting from 1 and increasing by increments of 1 (1, 2, 3, 4, ...).
What is a poset?
A poset, or partially ordered set, is a mathematical structure that consists of a set of elements and a relation that defines a partial order among those elements.
How are natural numbers related to posets?
Natural numbers can form a poset under the relation of "less than or equal to" (≤). This means that each natural number is related to all smaller numbers, and there is no number that is related to itself.
What is the poset structure of natural numbers under ≤?
The poset structure of natural numbers under ≤ is a chain, where each number is related to all smaller numbers and there is no element that is related to itself.
What are some examples of posets formed by natural numbers under ≤?
Some examples of posets formed by natural numbers under ≤ include the set of all even numbers, the set of prime numbers, and the set of perfect squares.
