Twins Paradox: Nature Cheats but B Gets Fooled
In summary, at event AA, Blue's clock is 800 seconds behind Green's clock. At event BA, Blue's clock is 4000 seconds behind Green's clock.
Stephanus
1,316
104
Dear PF Forum,
After all these post'. I want to know that my understanding of twins paradox is close enough.
So, Green travels, Blue stays.
Blue keeps sending signal, Green bounces the signal.
Doppler factor = 1/4, so ##\frac{1}{4} = \frac{1-v}{1+v}; v = 0.6##
And at event T0 (from B), Green changes direction. Blue can calculate the doppler effect and position, and know that G is at B.
At event A (above) Blue thinks that Green is at A1. Blue never knows that Green has changed frame.
And at event C (above) while Blue thinks that Green is at C1, suddenly the Doppler factor changes. From 0.25 to 4. Then Blue realize that Green is not at C1 but at C2. That Green has suddenly jump from a distance to a spot at C2.
So it mustn't be Green. It's something else who looks like Green whose time is dilated, and now Green's clock is speeding up from event C (above) until they meet. But the speeding up can catch up Blue's clock.
So, nature cannot be fooled, but nature fools B.
And for Green, at event T0, Green will see that Blue whose time is dilated, but now Blue's clock is speeding up and catches up Green's clock and still going on until they meet.
Is this how Twins Paradox work?
No. At event B, Green changes direction. As you go on to point out, Blue does not know about Green's change in direction until he receives a light signal from event B and sees Green's Doppler shift change, which is at event C (or one of them--your event labeling is not very good since multiple events have a "C" next to them).
No. Green doesn't "jump" at all; Green already changed direction, at event B. Event C is when Blue finds out about Green's change in direction and updates his model of Green's motion. Blue's model of Green's motion is not the same as Green's motion.
No. As above, Blue's model of Green's motion is not the same as Green's motion. Here you are confusing the two.
No. At event B, Green sees Blue's Doppler shift change. But at event B, Green is not seeing light signals from event T0; he's seeing light signals from an event on Blue's worldline that you've labeled "B", but which should have some different label to avoid confusion. Green does not see light from event T0 until later.
Not really; you have made several conceptual errors. See above.
Likes HallsofIvy
Okay...
Okay,... there are three section (A)Above, (G)Green, (B)Below. So the events labeled as CB, BB, AB for below. CG, BG, AG and CA,BA,AA.
I prefer to use 1 letter event so the picture won't be crowded.
First before I response to your post. I would like to ask a simple question:
Rule of the game:
AB sends signal to AG containing his own clock. AG bounces back the signal to AA with AB clock and AG clock.
BB sends signal to BG containing... ( the same rule).
So, at
Event AA:
AA clock: 3200
AG clock: 2000 (is this relevant to our calculation?)
AB clock: 800
Event BA
BA clock: 4000
BG clock: 2500 (is this relevant?)
BB clock: 1000,
So (BA-AA) = 800; (BB-AB) = 200; Doppler factor is 4. What V, ##4 = \frac{1+V}{1-V}; V = 0.6##So speed is 0.6c.
Direction: Green is receding.
Question: Can Blue calculate where Green is?
Thanks.
Based on what information? If you mean, based on the information he receives prior to event BA, no, he can't, because he hasn't yet seen Green change direction. Based on information he receives after event BA, yes, he can, because he has now seen Green change direction.
What if we shift BA, BG, BG 1 milisecond below. Just before Green changes direction.
Can Blue determine Green position?
But how do Blue knows that Blue can/cannot determine Green direction?
And how do Blue knows that Green has/hasn't changed direction.
I just want to know about particular answer.
We see something blue-shifted. We substract it with doppler factor, and we "know" it's not violet, it's somewhat "orange"
We see a clock's speeding toward us, we subtract it with doppler factor, actually it's a little bit slower than our clocks.
We see a clock's runs slow, we subtract it with doppler factor, actually it's not that slow. It moves away from us.
Speed? We know at once from dopper factor.
What about distance?
Same answer as before: if Blue doesn't yet have the information that Green changed direction, then Blue's calculation of Green's position might be incorrect.
He doesn't, if he hasn't yet seen Green change direction. Blue's information about Green is always "delayed", because it takes light time to travel from Green to Blue. That's always going to be true. I don't see why it's a problem.
The Doppler shift alone can't tell you about distance. You need some other information. For example, in your scenario, Green starts out co-located with Blue, so Blue knows where Green was at that instant; and if Blue has continuous observations of Green's Doppler shift, he can calculate where Green is up to the point when Green emitted the light Blue is receiving at a given instant. To calculate anything about Green after that point, Blue must make some assumption about how Green moves after the last point Blue actually observed him. Again, this is always going to be true, and I don't see why it's a problem.
Related to Twins Paradox: Nature Cheats but B Gets Fooled
1. What is the Twins Paradox?
The Twins Paradox is a thought experiment in physics that explores the concept of time dilation in the context of two individuals, one of whom travels at high speeds in space while the other stays on Earth. It raises questions about the nature of time and the effects of relativity on the perception of time.
2. How does the Twins Paradox demonstrate the concept of time dilation?
In the Twins Paradox, one twin stays on Earth while the other travels at high speeds in space. According to the theory of relativity, time moves slower for the twin traveling at high speeds. This means that when the traveling twin returns to Earth, they have aged less than their twin who stayed on Earth, demonstrating the concept of time dilation.
3. Why is the Twins Paradox often referred to as "Nature Cheats but B Gets Fooled"?
The phrase "Nature Cheats but B Gets Fooled" is a popular way to describe the Twins Paradox. This is because it appears that nature is "cheating" by allowing one twin to travel at high speeds and experience less time, while the other twin is "fooled" into thinking that time has passed at a normal rate. In reality, both twins experience time at a normal rate from their own perspective, but it is the difference in their reference frames that causes the apparent discrepancy in time.
4. Can the Twins Paradox be observed in real life?
While the Twins Paradox is a thought experiment, there have been real-life experiments that have confirmed the concept of time dilation. For example, atomic clocks on airplanes have been shown to tick slower than those on the ground, due to the high speeds at which the airplanes are traveling. However, it is not possible for humans to travel at speeds high enough to experience a significant difference in time like in the Twins Paradox.
5. What are the implications of the Twins Paradox in our understanding of time and space?
The Twins Paradox challenges our traditional understanding of time as a constant and absolute concept. It shows that time is relative and can be affected by factors such as speed and gravity. This has significant implications in fields such as physics and astronomy, and has led to advancements in our understanding of the universe and its laws.
