Nearly impossible complex algebra problem
In summary: You have two equations. :smile:Compare the real and imaginary parts on both the sides.And check your equation again. It is wrong.OK. The new equation:x2 -2 - y2 -y +2xi(y+1) = 0.What do you mean with comparing both sides? x = Re(z) and y = Im(z), but how does that help me?OK. The new equation:x2 -2 - y2 -y +2xi(y+1) = 0.The SolutionTo solve this, you need to find all complex numbers s such that Im(-z + i)= (
Nikitin
735
27
https://wiki.math.ntnu.no/lib/exe/fetch.php?hash=d26b1f&media=http%3A%2F%2Fwww.math.ntnu.no%2Femner%2FTMA4115%2F2012v%2Fexams%2Fkont.eng.pdf
Assignment 1.
"Find all complex numbers s such that Im(-z + i)= (z+i)2"
What do I do?
I got to Im(-z) + 1 = z2+2zi -1 => Im(-z) = (z-1+i)(z+1+i).
But I have no idea what to do next... Or if I even have done anything useful so far.
Help?
I can't see any other way than substituting z=x+iy. Try that, it is easy to solve. There might be some other method too.
Assignment 1. What do I do?
Instead of posting a link to a PDF, why not just enter the text of the problem here? Some members figure that if the OP isn't willing to take the time to provide the problem statement, why should they bother?
Help?
I did not mean it like that - I simply can't do latex and thus it's easier to present the problem that way. I apologize if you got offended by the OP or by the title. Anyway I typed-in the problem into the OP
Pranav-Arora: OK, thanks!
Pranav-Arora: the solution says ±√2 - i. I duno why.
Did you try what I said?
Likes 1 person
a second, please
No, I wasn't offended by your post or the title. It takes a lot more than that to offend me. It's just that it's much more convenient for readers if the problem statement is right here, not off on some other web site.
For many problems, including this one, you don't need LaTeX. There are some controls build into this site (click the Go Advanced button under the entry pane to see them). The only "mathematical" things you needed for this problem are exponents, which you can do by clicking the X2 button in the advanced menu that appears after you click Go Advanced.
Thank you - much appreciated.
Pranaev: I get x2 -2 - y2 -y +2xi(y+1) = 0. I have to unkowns and only one equation..
Nikitin said:
I get x^2 + 2x -2 - y^2 -y +2yi(x+1) = 0. I have to unkowns and only one equation..
Nope, still wrong. Show your steps so that we can point out the error.
For example, you have something like a+ib=3+2i, you can compare the real and imaginary parts on both sides and get a=3 and b=2. Similarly, you have 0+0i on RHS in this case.
I used the 0 + 0i trick to get the correct answer. Thanks :)
FAQ: Nearly impossible complex algebra problem
What is a nearly impossible complex algebra problem?
A nearly impossible complex algebra problem is a mathematical equation or expression that is extremely difficult to solve due to its complexity and the use of complex numbers. It often involves multiple variables and operations, making it challenging for even experienced mathematicians.
How do you approach solving a nearly impossible complex algebra problem?
Solving a nearly impossible complex algebra problem requires a combination of knowledge, experience, and problem-solving skills. It is important to break down the problem into smaller, more manageable parts and to use various strategies such as substitution, elimination, and graphing to simplify the problem and find a solution.
Why are nearly impossible complex algebra problems important in the field of science?
Nearly impossible complex algebra problems are important in science because they often arise in real-world scenarios and can help scientists understand and model complex systems. This type of problem-solving also trains scientists to think critically, logically, and creatively.
What are some tips for tackling a nearly impossible complex algebra problem?
Some tips for tackling a nearly impossible complex algebra problem include breaking it down into smaller parts, using different strategies and techniques, seeking help or collaborating with others, and practicing regularly to improve problem-solving skills.
Can technology be helpful in solving nearly impossible complex algebra problems?
Yes, technology can be extremely helpful in solving nearly impossible complex algebra problems. Graphing calculators, computer algebra systems, and other software can help visualize and manipulate complex equations, making them easier to solve. However, it is important to have a solid understanding of the underlying concepts and not rely solely on technology.
