Need a hint for this triple integral
In summary, the problem is that the integrand is not a simple antiderivative, so you will have to be clever and interchange the limits of integration. You will also need to plot the region to help visualize the problem.
littlebearrrr
25
Evaluate the triple integral of sin2z/(4-z) dydzdx where the limits of integration for outer limits (x) are from 0 to 2, the middle limits (z) are 0 to 4-(x^2), and the inner limits (y) are 0 to x.
I'm not sure what the best approach is for this integral. Should I start by tackling the hardest one (dz), or work on the dx and dy integrals where the integrand is a constant? My attempt at the problem involved integrating wrt x first, then wrt y. I got the integral of 2xsin2z/(4-z) dz, from 0 to 4-x^2. I guess what's throwing me off is that trig function. Only thing I can think of is by parts...
Edit: Integrated wrt y then wrt x, got 2sin2z/4-z, so that's a bit simpler. Still need to integrate wrt z. I'm thinking by parts but wondering if there's a more efficient way that I might be missing.
Hi, there!
Your major problem is that you don't have any simple antiderivative of the integrand with respect to z!
Thus, you will need to be clever, and interchange the limits of integration.
Now, to give you a tip:
[tex]z=4-x^{2}\to{x}=\sqrt{4-z}[/tex]
[tex]0\leq{y}\leq{x}\to{0}\leq{y}\leq\sqrt{4-z}[/tex]
Lastly, unless you have changed the integration limits, you CANNOT switch order of integration, say x-integration prior to z-integration.
Likes 1 person
Hi, thank you for responding! Okay, I changed the limits of integration for y. After integrating for y and simplifying the new integrand, I got sqrt(4-z) * sin2z / 4-z = sin2z/sqrt(4-z). But since x=sqrt(4-z), then sin2z/sqrt(4-z) = sin2z/x (is that a correct statement to make?). From there, I integrate sin2z/x with respect to z from 0 to 4-(x^2). This is a complicated path to take so I just wanted to make sure I'm headed down the right track. :)
"But since x=sqrt(4-z), then sin2z/sqrt(4-z) = sin2z/x (is that a correct statement to make?)."
Hmm..no. The UPPER LIMIT for the variable "x" equals sqrt(4-z), the variable x lies in the interval 0<=x<=sqrt(4-z)
It also seems that I made a severe messup in what I said about "y". Sorry about that!
Thus, if we set up the entire integral, with "z" as outermost variable, we have:
[tex]I=\int_{0}^{4}\int_{0}^{\sqrt{4-z}}\int_{0}^{x}\frac{\sin(2z)}{4-z}dydxdz[/tex]
Likes 1 person
Interesting integral. Like the other two where we needed to remove the x or z in the denominator. May I also add that it might be helpful if you plotted the region. This is Mathematica code:
Code:
p1 = Plot3D[x, {x, 0, 2}, {y, 0, 4}, BoxRatios -> {1, 1, 1},
   PlotStyle -> Opacity[0.5]];
p2 = ParametricPlot3D[{x, 4 - x^2, z}, {x, 0, 2}, {z, 0, 2},
   RegionFunction -> Function[{x, y, z}, z <= x],
Show[{p1, p2}]
Now, run the code and by interactively rotating the region as necessary, try to visualize how you can reorder the order of integration in all possible ways and then check the results numerically to verify that they agree with the way above (just a suggestion). And if you're really good, actually modify my code to include graphics which shows how the differentials are summed up like you see in the Calculus textbooks. That in my opinion helps you understand how the reordering works.
Likes 1 person
@ arildno: That's all right! I appreciate all of your help and patience so far; your wonderfully detailed posts helped me see this type of integral from a different perspective, and I learned the usefulness of changing the limits. I attempted to evaluate it again, and I got (1/4)(1-cos8). (or approximately 0.286)
@ jackmell: Wow! I greatly appreciate the effort you made to represent this problem graphically. It's embarrassing, but I actually don't have/use mathematica (nor any other of the related software), but it's something I'm going to start learning pretty soon. I saved your post so that I can look back at it again in the future. In the meantime, I found this plot extremely useful in helping me visualize this region in 3-space. Thank you!
FAQ: Need a hint for this triple integral
What is a triple integral?
A triple integral is an extension of the concept of a single or double integral in calculus. It is used to find the volume of a three-dimensional shape, such as a solid region in space.
How is a triple integral set up?
A triple integral is written as ∫∫∫ f(x,y,z) dV, where f(x,y,z) is the function being integrated and dV represents the infinitesimal volume element.
What are the limits of integration in a triple integral?
The limits of integration in a triple integral depend on the shape of the region being integrated. For example, for a rectangular solid, the limits would be the lower and upper bounds of the x, y, and z coordinates.
What is the purpose of using a triple integral?
The purpose of a triple integral is to find the volume of a three-dimensional shape or to solve problems involving mass, center of mass, and other physical quantities in three dimensions.
What are some tips for solving a triple integral?
Some tips for solving a triple integral include breaking down the region of integration into simpler shapes, using symmetry to simplify the integral, and using substitution to make the integral more manageable.
