Need a real life example where a partial derivative is used in motion
nrsakinh
I have to find a real life application of partial derivative and have chosen the topic "Motion". I need examples of where the partial derivative is used to calculate speed/acceleration or in projectile motion.
my group is preferring the ue of partial derivative to find the acceleration of a car or the projectile motion of something being launched
Have you heard of the Schrodinger equation?
Rocket flight. You have to consider both the change in velocity and the change in mass.
That is a very good example. Consider a flying airplane. several forces are easiest to consider in different coordinate systems that are rotating with respect to each other. Engine forces line up with the aircraft fuselage. Gravity always lines up in locally level Earth coordinates. Aerodynamics forces line up with the relative air flow. Those are all rotating with respect to each other, so there are partial derivatives all over the place.
But even without considering that, looking at one rotating coordinate system, the equations of motion in six degrees of freedom (6-DOF EOM) have a lot of partial derivatives. Look at the those equations and see if you have further questions. We are only allowed to give hints and direction for homework-type questions. You have to show us your work to get more help. (see this)
PS. Do not get discouraged if the equations seem overwhelming. Many of us, myself included, are still struggling with it.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
