Electrical Need advice on building a linear particle accelerator
A high school freshman is attempting to build a linear particle accelerator (DTL) and seeks guidance on calculating the drift tube length. The student uses the equation V=√(2eV/m) to determine the velocity of electrons generated from a custom-built electron gun. The setup includes tri clamp stainless steel pipes as a vacuum tube, and a TAG-101 signal generator producing 1 MHz, which will be connected to a self-made flyback transformer. The student plans to ground the vacuum tube to act as a Faraday cage to mitigate electromagnetic radiation risks. However, concerns are raised about the safety challenges associated with building a particle accelerator, including the potential for ionizing radiation, X-ray production, and high voltage hazards. It is recommended that the student find a skilled mentor for guidance and consider safer experiments, such as building a cloud chamber or conducting Millikan's oil drop experiment, which pose fewer safety risks.
SamuelCunningham3456
I am a freshman in highschool and I plan on building a linear particle accelerator (DTL) I need help finding out how to find the drift tube length. I use the equation V=√(2eV/m) (where V is equal to the velocity. E is the elementary charge of the electron 1.602 x 10^-19. V is the applied voltage. M is the mass of the electron 9.109x10^-31) to find the velocity of the electron coming from the electron gun. ( The attached image is the type of electron gun I have built.) I am using tri clamp stainless steel pipes as the vacuum tube where the drift tubes will be inside.
I have a TAG-101 signal generator witch can produce 1 MHz then ill find a way to plug that into a flyback transformer witch will be made by me because flyback transformers online usually have diodes at the end to suppress the AC. because i'm using high voltage and high frequency i will ground the stainless steel vacuum tube so it can act like a faraday cage to reduce potential electromagnetic radiation. I am aware of the dangers this project has i know it can produce Ionizing radiation when engaged
That's what i'm doing i would love to here how i can improve this and if some of yall can help me find the drift tube length.
Thread paused for a bit for Moderation...
After a Mentor discussion, this thread will remain closed.
The issue is that it is very difficult to build a particle accelerator and do it safely. There are issues with X-rays and vacuum safety and high voltage safety that cannot be properly addressed in a discussion forum like PF.
@SamuelCunningham3456 -- it is good that you are so curious and motivated to learn more about science and experimental apparatus. Please be sure to find a very experienced and skilled personal Mentor there were you live to help you with whatever projects you want to build. You might consider building a cloud chamber instead or do Millikan's oil drop experiment, since those involve fewer safety issues.
Please be safe, and enjoy your pursuit of science. :smile:
Likes SamuelCunningham3456
The idea is to use water to shift the centre of gravity of the pendulum by a small amount. The pendulum rod will have a tube closed at the bottom and open at the top. A second similar tube will be mounted nearby and will act as a reservoir. The water will be transferred using a peristaltic pump driven by a stepper motor and will travel via a thin flexible silicon tube. A loop arrangement will minimise friction at the pendulum's fulcrum. The silicon tube will extend to the bottom of the...
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
