Need clarification about x-t and v-t graph
  • Thread starter mizzy
  • Tags
    Graph
In summary, negative slope on an x-t graph represents uniform negative velocity, while on a v-t graph it represents constant deceleration. The sign indicates the direction of motion, and opposing signs mean slowing down. Instantaneous velocity may not exist in the real world, but it is a useful concept to understand motion graphs.
mizzy
217
I'm confused with what a negative slope means on an x-t and v-t graph.
On an x-t graph, I understand that a positive constant slope means uniform velocity and when the slope is 0, then the object is stationary. On a v-t graph, constant slope means constant acceleration and a zero slope means constant speed.
What does the negative slope mean? is the object slowing down?
Can someone please help me get a clearer understanding of this? THANKS
On an x vs. t graph:
If the slope is positive, then the velocity is constant and positive.
If the slope is zero, then velocity is zero.
If the slope is negative, then velocity is constant and negative.
On a v vs. t graph:
If the slope is positive, then the acceleration is constant and positive.
If the slope is zero, then the acceleration is zero.
If the slope is negative, then the acceleration is constant and negative.
Generally speaking, acceleration is the derivative of the equation for velocity with respect to time (a = dv/dt), and velocity is the derivative of the equation for position (v = dx/dt).
Hope that helps.
Linear negative slope on a x-t graph means uniform negative velocity. The object is moving in the opposite direction.
Linear negative slope on a v-t graph means constant deceleration. Or said in another way, constant negative acceleration.
but does it mean that the object is slowing down?
Depends. If acceleration and velocity are both the same sign (negative vs. positive), then it's speeding up. If the signs are different, it's slowing down. I think that's correct.
ok. so basically the negative or positive sign just tells us the direction and not if is speeds or slows down. correct??
i came across this question? If the average velocity of an object at a certain time interval is zero, what is its displacement? What's happening to the object?
If the average velocity is zero, the object is stationary. is that right?
Correct on the signs. Well, sort of - opposing signs mean slowing down when you're talking velocity and accel.
Correct on the displacement. Δx = Δv / Δt ; if Δv = 0, then Δx = 0/t.
Wow, that seems very cumbersome if you're just trying to understand what is being represented on a graph. It's almost like memorization if you are trying to attach the concept of slope to its actual physical meaning. I've got a question for all of you - is there really such a thing as "instantaneous velocity", in the real physical world? If you can answer that, then you understand motion graphs.
FAQ: Need clarification about x-t and v-t graph
What is an x-t graph?
An x-t graph, also known as a position-time graph, is a visual representation of an object's position (x) over time (t). It shows how the position of the object changes over a specific time period.
How is an x-t graph different from a v-t graph?
An x-t graph shows an object's position over time, while a v-t graph shows an object's velocity (v) over time. The slope of an x-t graph represents an object's velocity on a v-t graph.
What does a flat line on an x-t graph mean?
A flat line on an x-t graph means that the object is not moving and its position remains constant over time.
How is acceleration represented on an x-t graph?
Acceleration is represented by the slope of a line on an x-t graph. A steeper slope indicates a higher acceleration, while a flat line (zero slope) indicates no acceleration.
How can an x-t graph be used to determine an object's displacement and average velocity?
The area under the curve on an x-t graph represents an object's displacement. The slope of a line connecting two points on the curve represents the object's average velocity between those points.
