mathmari
MHB
- 5,049
- 7
Hey! ![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have the following in my notes:
$$u_t+A(x,t,u)u_x=b(x,t,u) \ \ \ \ \ \ \ \ \ \ (1)$$
$$u=(u_1, \dots, u_n), b=(b_1, \dots, b_n)$$
$$A=[a_{ij}], i,j = 1, \dots, n$$
We set the question if there are characteristic directions at the path of which the PDE system $(1)$ is reduced to an ODE system.
So we take linear combinations of the above equations.
We use the vector $\gamma=(\gamma_1, \dots, \gamma_n) \ \ \ \ \ \ \ \ \ \ (2)$.
We take $\gamma^T(u_t+Au_x)=\gamma^Tb \ \ \ \ \ \ \ \ \ \ (3)$.
We want to conclude to a form of total derivative of the linear combination of $u$.
That means:(we consider that $u_j=u_j(x(t),t)$)
$$\frac{d}{dt}(\gamma_1u_1+\gamma_2u_2 +\dots+\gamma_n u_n)=\frac{\partial}{\partial{t}}(\gamma_1u_1+\gamma_2u_2 +\dots+\gamma_n u_n)+\frac{dx}{dt} \frac{\partial}{\partial{x}}(\gamma_1u_1+\gamma_2u_2 +\dots+\gamma_n u_n)$$
and we define $\frac{dx}{dt}=\lambda$
The relation above means:
$$m^T(\frac{\partial{u}}{\partial{t}}+\lambda\frac{\partial{u}}{\partial{x}})=\gamma^Tb \ \ \ \ \ \ \ \ \ \ (4)$$
From the relation $(3)$ and $(4)$, we see that $\gamma=m=(\gamma_1, \dots, \gamma_n)$ and that $\gamma^TA=\lambda \gamma^T$
$\lambda:$ eigenvalue of the matrix $A$
$\gamma^T:$ left eigenvector of $A$
We define the characteristic directions:
$\frac{dx}{dt}=\lambda$, so $\gamma^T(\frac{\partial{u}}{\partial{t}}+\frac{dx}{dt}
\frac{\partial{u}}{\partial{x}})=\gamma^Tb$
$\gamma^T \frac{du}{dt}=\gamma^Tb$
(To can reduce the system to a PDE system, the $\frac{dx}{dt}=\lambda$ must exist. To be able to apply this method, the matrix $A$ should have $n$ real values.)
We conclude that to reduce the PDE system to an ODE system, the matrix $A$ should have $n$ discrete real eigenvalues.
In this case we say that the system is hyperbolic.
Could you explain me what we have done here? I got stuck right now... (Wondering)
