Need help computing force of a defibrillator
In summary, the doctor could reach a maximum height of .0217 meters if he was launched straight up from the defibrillator.
Quinn Pochekailo
In a TV-show, an inexperienced doctor touches the electrodes of a defibrillator and gets thrown across the room. For a moment assuming that all the energy (and only the energy) from the defibrillator goes into tossing him around, what is the maximum height above ground he could reach (i.e., if he was launched straight up)? Data: mass of doctor 93 kg, capacitance of capacitor in defibrillator 110 μF, voltage 600 V.
I think I use F=mgh
To calculate farads, I did (110 x 10^-6) / 600 to get 1.833 e-7. I also drew a free body diagram as the force in the y upward component must exceed that of the y downward component, which is just equal to F = 93 * 9.8.
Any help with more relevant equations would be greatly appreciated. I have been racking my brain with this problem.
I think I use F=mgh
Welcome to the PF.
The equation you wrote is not correct. I think you meant to say that the potential energy that a raised mass has is PE=mgh.
This problem is best solved by equating the initial energy in the capacitor to the final gravitational potential energy of the person. Do you know the Relevant Equation for the energy stored on a capacitor in terms of the capacitance and voltage? :smile:
Based off my notes from lecture, the closest equation I can find would be Energy = Q^2/2C
You are given capacitance and voltage in this question, and there is an equation that gives the stored energy in terms of those variables. If it's not in your notes, use Google Images or check wikipedia -- it's a very commonly-used equation. :smile:
I think I know what you are referring to, and it would be C= Q/V
Nope. It only involves C and V...
Energy = (1/2)CV^2?
Energy = (1/2)CV^2?
Yes, now equate that initial stored energy on the capacitor to the final PE of the person, and calculate the maximum height that they reach.
Okay so my calculations are .5(110 * 10^-6)* (600^2).
The stored energy would be 19.8 volts/charge, which I divide by (9.8*93) which would give me the height in meters.
Thank you for the help berkeman!
A couple tips -- be sure to list and carry your units along with the calculations. That will help you to get familiar with checking your work, and with expressing the answers in the correct units.
Can you re-write your equations carrying units along with the numbers? And stored energy should be expressed in units of Joules... :smile:
Sure.
(1/2) * (110 microfarads * 10^-6) * (600 V^2) = 19.8 J
19.8 J = mgh
19.8 J = (93 kg) (9.8 m/s2) h
h = .0217 m
Thank you for the tips and advice.
Likes berkeman
FAQ: Need help computing force of a defibrillator
What is the purpose of computing the force of a defibrillator?
The purpose of computing the force of a defibrillator is to determine the amount of electrical energy that will be delivered to the heart during a shock. This information is critical for ensuring that the defibrillator is delivering the appropriate amount of energy to effectively restore the heart's rhythm.
How is the force of a defibrillator measured?
The force of a defibrillator is typically measured in joules, which is a unit of energy. This measurement can be obtained by multiplying the voltage of the defibrillator by the current and the duration of the shock. The result is then typically converted to joules for easier interpretation.
What factors affect the force of a defibrillator?
The force of a defibrillator can be affected by several factors, including the type of defibrillator being used, the energy setting selected by the user, the impedance (resistance) of the patient's body, and the placement of the defibrillator pads on the patient's chest. Other physiological factors, such as the patient's body size and underlying health conditions, can also impact the force of the defibrillator.
How can the force of a defibrillator be adjusted?
The force of a defibrillator can be adjusted by changing the energy setting on the device. Most defibrillators have pre-set energy levels or allow the user to manually adjust the energy. Some modern defibrillators also have an automated energy selection feature that calculates the appropriate energy level based on the patient's body size and impedance.
Why is it important to accurately compute the force of a defibrillator?
Accurately computing the force of a defibrillator is crucial for ensuring the safety and effectiveness of the shock delivered to the patient. If the force is too low, the shock may not be strong enough to revive the heart, while a force that is too high could cause harm to the patient. By accurately computing the force, healthcare professionals can confidently use a defibrillator to save a patient's life.
