Need help deciphering this number theory problem
In summary, the conversation discusses the meaning of the triangle symbol in relation to ideals in a ring. It also addresses the definition of addition of ideals and the concept of equivalence mod an ideal. The conversation also covers the solvability of a system of congruences with coefficients of 1.
1MileCrash
1,342
41
What does triangle line mean? What is "+" for sets here?
Once I know that, if I need assistance, I will show an attempt. Otherwise I will be satisfied. :)
The triangle means "is ideal of". So ##K_1## and ##K_2## are ideals of ##R##. We then define
[tex]K_1 + K_2 = \{a+b~\vert~a\in K_1,~b\in K_2\}[/tex]
This is again an ideal of the ring.
Ok, and while we're at it, what on Earth does equivalence mod "an ideal" mean? Does it mean the full set of equivalences for all elements in an ideal?
I am referring to the statement "x =K1 a." I just realized the picture is sideways.
And why is it stating that "if the following system is solvable.." since when is a system of congruences with coefficients of 1 ever not solvable?
Thank you.
It means ##x-a\in K_1##.
For example, the system ##x\equiv_2 0##, ##x\equiv_2 1## is not solvable. This is equivalence modulo the ideal ##2\mathbb{Z}##.
Alrighty, thanks for filling in the gaps for me, hah!
FAQ: Need help deciphering this number theory problem
What is number theory?
Number theory is a branch of mathematics that deals with the study of integers and their properties. It involves understanding patterns and relationships between numbers, as well as solving complex problems related to integers.
How can I approach a number theory problem?
The first step in approaching a number theory problem is to carefully read and understand the problem statement. Then, try to break down the problem into smaller, more manageable parts. Look for patterns and relationships between numbers and try to use known theorems or formulas to solve the problem.
What are some common techniques used in number theory?
Some common techniques used in number theory include prime factorization, modular arithmetic, and the use of mathematical proofs. Other techniques may vary depending on the specific problem being solved.
How do I know if my solution to a number theory problem is correct?
To verify the correctness of your solution, you can use mathematical proofs or test your solution with different numbers. It is also helpful to have someone else check your work for any errors or mistakes.
What are some real-world applications of number theory?
Number theory has many practical applications, such as in cryptography, coding theory, and computer science. It is also used in fields such as physics, engineering, and economics to model and solve various problems involving integers.
