Krion
- 2
- TL;DR Summary
- I need to build a clock that triggers a signal to repeat three times at equal intervals. These intervals need to be adjustable within a short amount of time (i.e. striking three times with 30 seconds in between to striking three times with 90 second intervals).
Hello! I am in need of a clock expert. Just a disclaimer, I am vastly unfamiliar with much of the inner-workings of clocks and need some help. I have only built a simple Graham Escapement clock, previously.
I need to build a clock that triggers a single signal to occur three times at equally spaced time intervals. These time intervals need to be adjusted after each trial for a total of three trials (we are only given five minutes to adjust). We are also only limited to mechanical clocks and no electrical components. I was looking into striking clocks, but I am unsure of whether you are able to adjust the interval at which it strikes or if it is even doable considering my inexperience. I have also considered adding a lever system that triggers a visual signal, but the dropping weight does not strike the lever with enough force to trigger it. Currently, I am trying to research more into it, but I find it hard to understand a lot of material. A bit of advice would be greatly appreciated!
