Need help finding a suitable piezo actuator
In summary: I'm not sure about the hertz, but it is probably referring to the vibration frequency of the actuator. I'm not sure about the hertz, but it is probably referring to the vibration frequency of the actuator.
ToInfinity
Hi there,
I'm an undergrad and I'm designing a system at the moment. It utilizes a LRA (Linear Resonant Actuator), but I'm in need of much higher accelerations than what it offers. The current device is small (about 10 mm), circular, and produces about 1.7G of acceleration on a 100g object. A link of what I am currently using can be found here: https://catalog.precisionmicrodrive...10-000-10mm-linear-resonant-actuator-3mm-type
However, for many reasons, from my research I have determined that it would be better to utilize a piezoelectric actuator.
I am not very experienced in this field though and am wondering if I could get much larger accelerations (5-10G+) at somewhat similar frequencies out of a piezo actuator that is about the same size.
Thanks for the help!
I've worked with LRAs before, but not piezo actuators. From a few google searches it seems as though most piezo sites use force as a measurement and they are capable of generating many thousands of Newtons so you should be able to get your acceleration. They also show some resonance frequencies, but I'm not sure if that's the vibration frequency or something else. They also use the term stroke, and I'm not sure if that's the amount the actuator moves or the device it is attached to. I'm also not sure about the size and how the piezo actuator works (they require large voltages, but I'm not sure about the current/how it works, etc...).
Hopefully this helped at least a little bit. Maybe another physics forum member can chime in and help fill in the gaps :)
Likes ToInfinity
The OP omitted a key requirement. How much distance (travel) must the actuator move. A high force piezo actuator I found on google only has a travel of 300 micro-meters.
Likes ToInfinity
I don't really care how much the actuator moves, just how much acceleration/frequency it provides to the object it is affecting. Any additional information on how the actuator/whole system moves is just a plus.
Then I don't understand why you had to post this question. I did a google search on piezoelectric actuator. One of the http://www.physikinstrumente.com/product-detail-page/p-007-p-056-102600.html gave a table of specifications for dozens of different models.
Displacement
Diameter OD
Length L
Blocking force
Stiffness
Electrical capacitance
Resonant frequency
What more information do you need?
Nice. I'm bookmarking this one.
I'm sort of confused about the resonance frequency. I get that at the mechanical resonance it vibrates most effectively, but to my understanding a hertz is a cycle a second...but if things are like 126 kHz does that mean they vibrate 126,000 times per second?
Related to Need help finding a suitable piezo actuator
1. What is a piezo actuator?
A piezo actuator is an electromechanical device that converts electrical energy into mechanical motion using the piezoelectric effect. This means that when a voltage is applied to a piezoelectric material, it will change shape, allowing for precise and fast movements.
2. Why would I need a piezo actuator?
Piezo actuators are commonly used in applications where precise and fast movements are required, such as in positioning systems, nanopositioning, and micromanipulation. They are also used in areas such as robotics, medical devices, and aerospace technology.
3. How do I choose the right piezo actuator for my application?
When selecting a piezo actuator, you should consider factors such as the required displacement, frequency of movement, operating voltage, and environmental conditions. It is also important to consider the size and weight of the actuator, as well as its compatibility with your control system.
4. What are the different types of piezo actuators?
There are several types of piezo actuators, including stack, tube, bender, and shear actuators. Stack and tube actuators are most commonly used for precise positioning, while bender and shear actuators are better suited for applications that require large displacements.
5. Where can I find a suitable piezo actuator?
There are many companies that specialize in producing and selling piezo actuators. It is important to do thorough research and compare different options to find the best fit for your specific application. You can also consult with a knowledgeable supplier or engineer for recommendations based on your requirements.
  • Electrical Engineering
  • Atomic and Condensed Matter
  • STEM Academic Advising
