Need help finding the buoyant force in this problem
In summary, the conversation is about a question asking how many wooden beams a team of 6 scouts will need to successfully cross a lake on a raft they designed. The average density of the beams is 0.80 and the average mass of the scouts is 65kg. The method suggested by the tutor involves calculating the total force on the raft and solving for the number of beams needed. The student's algebra initially resulted in 0, but the correct solution is to set the forces from the beams and scouts equal to 0 and solve for n.
TheKShaugh
Hi everyone,
This question is killing me, I don't know why but I just can't get my head around it.
A team of 6 scouts plans to cross a lake on a raft they designed.
The scouts have wooden beams with an average density of .80. The beams measure 30cm x 30cm x 3m.
The average mass for the team members is 65kg, and for their safety, they want the top of the raft to be at least 3 cm above the surface of the water.
How many beams will they need to complete their project successfully?
I'm not sure if I need to post them. f = mg is the main one.
My tutor gave me this method:
Fg(scouts) = 65 x 9.8 x 6
V(beam) = .27m^3
Fg(beam) = 800 x 9.8 x .27
Fg(raft) = Fg(beam) x n [n = number of beams]
Fg(total) = Fg(scouts) + Fg(raft)
Fb = 2381 x n
Fb = Fg(total) = Fg(scouts) + Fg(raft).
Solve for n.
Now I'm just a lowly high school student so my math isn't all that great, and when I do this I end up getting 0. The equation as I write it out is
2381n = -3822 - 2116n = -3822 - 2116n
6713n = -3822 +3822
6713n = 0
Could anyone help me out with this question?
Thanks,
Kevin
Your algebra has taken a wrong turn.
Fg = -3822 - 2116n
Fb = 2381n
From statics, we know that Fb + Fg = 0 (there is no net force on a floating object)
so, 2381n -3822 - 2116n = 0
Solve for n
6713n = -3822 +3822
Try that step again.
Fg = -3822 - 2116n
Fb = 2381n
Solve for n
Thank you. You truly are the king of kings.
Hello Kevin,
I can understand why this problem may be confusing for you. Let's break it down step by step.
First, we need to understand the concept of buoyant force. This is the force exerted by a fluid (in this case, water) on an object immersed in it. It acts in the opposite direction of gravity and is equal to the weight of the displaced fluid.
In this problem, the scouts want the top of their raft to be at least 3 cm above the surface of the water. This means that the buoyant force must be equal to the weight of the raft plus the weight of the scouts.
To find the weight of the raft, we need to know its volume and density. The volume of the raft is 30cm x 30cm x 3m = 0.27m^3. The density of the wooden beams is given as 0.80, so the weight of the raft is 0.80 x 0.27 x 9.8 = 2.106 N.
Next, we need to find the weight of the scouts. This is given as 65 kg x 9.8 = 637 N.
Therefore, the total weight that the buoyant force must support is 2.106 N + 637 N = 639.106 N.
Now, we can use the formula Fb = ρVg, where Fb is the buoyant force, ρ is the density of the fluid (in this case, water), V is the volume of the displaced fluid, and g is the acceleration due to gravity (9.8 m/s^2).
We know that the scouts want the top of the raft to be at least 3 cm above the surface of the water, so the volume of the displaced fluid is 0.27m^3 + 0.03m^3 = 0.3m^3.
Plugging in the values, we get:
Fb = 1000 x 0.3 x 9.8 = 2940 N
Since we want the buoyant force to be equal to the total weight of the raft and scouts, we can set up the equation:
2940 N = 639.106 N + 0.8 x 0.27 x n x 9.8
Solving for n, we get n = 22. So, the scouts will need 22
FAQ: Need help finding the buoyant force in this problem
1. What is the definition of buoyant force?
Buoyant force is the upward force exerted by a fluid on an object that is submerged or floating in the fluid.
2. How do you calculate the buoyant force?
The buoyant force can be calculated using the formula Fb = ρVg, where Fb is the buoyant force, ρ is the density of the fluid, V is the volume of the displaced fluid, and g is the acceleration due to gravity.
3. What information do you need to find the buoyant force?
In order to find the buoyant force, you will need to know the density of the fluid, the volume of the displaced fluid, and the acceleration due to gravity.
4. How does the buoyant force affect an object?
The buoyant force acts in the opposite direction of gravity and helps to keep an object afloat or partially submerged in a fluid. It also determines whether an object will sink, float, or remain suspended in the fluid.
5. Can you give an example of how to find the buoyant force in a problem?
Sure, for example, if you have a cube with a volume of 0.5m^3 submerged in water with a density of 1000 kg/m^3, the buoyant force would be calculated as follows: Fb = (1000 kg/m^3) x (0.5m^3) x (9.8 m/s^2) = 4900 N. This means that the buoyant force acting on the cube is 4900 Newtons, which is equal to the weight of the displaced water.
