Need help fixing computer chair leather
  • Thread starter leroyjenkens
  • Tags
    Computer
In summary, the speaker is discussing their worn leather chair and how they would like to cover it with some kind of material to make it look better. Suggestions are made to use upholstery material, repurpose a leather jacket, or use duct tape. The speaker also mentions their experience with re-upholstery and their mother's satisfaction with their work.
leroyjenkens
616
49
I've had this chair for about 5 years, and the leather on it wore thin from lots of sitting and moving, and now the leather on the seat and part of the back is completely worn away to where the cloth cushion is showing.
I'd like to just cover the back and seat with some kind of material (colored black to match the chair) so it doesn't look so bad. Does anyone have any ideas on what material I could buy and how to apply it to the chair?
Thanks.
Computer science news on Phys.org
Any fabric store should have upholstry material by the yard.
For leather you can go down to the thrift or second hand clothing store and sometimes get a long leather jacket for a song. Take the seams apart and voila you have some leather to match your chair.
You could just hem the ends of the material and use some nice looking cord to tie it to the seat or over the back from the corners or wherever necessary.
I have done some re-uphostry jobs in my time and they turned out quite well. My mother was especiallt pleased with hers but mothers are supposed to be like that.
Vinyl upholstery material would be a good, sturdy option.
It would be sheer blasphemy to use anything other than duct tape.
I am not an expert in furniture repair, but I can offer some suggestions based on my knowledge of materials and their properties. First, I would recommend looking for a durable and flexible material that can withstand frequent sitting and movement. Leather is a popular choice for its durability, but there are also synthetic options available that may be more affordable and easier to work with.
When selecting a material, consider its thickness and how it will adhere to the chair. Adhesives specifically designed for furniture repair may be helpful in securing the material to the chair. It may also be beneficial to reinforce the worn areas with a patch of fabric or leather before applying the new material.
In terms of application, I would suggest carefully measuring and cutting the material to fit the back and seat of the chair. It may be helpful to use a template or tracing of the chair's shape to ensure a precise fit. Once the material is cut, follow the instructions for the adhesive and carefully apply it to the chair, smoothing out any wrinkles or bubbles as you go.
Overall, it may be best to consult with a professional furniture repair person for more specific advice and guidance on materials and techniques. They may also be able to provide a more permanent solution for your worn chair. Good luck with your repair!
FAQ: Need help fixing computer chair leather
How do I fix a rip in my computer chair's leather?
The first step is to thoroughly clean the area around the rip with a leather cleaner and let it dry completely. Next, you can use a leather repair kit to patch up the rip. Follow the instructions on the kit and make sure to smooth out any air bubbles. Allow the repair to dry fully before using the chair again.
What if the leather on my computer chair is peeling?
If the leather on your computer chair is peeling, it is likely due to wear and tear. You can try using a leather conditioner to rehydrate the leather and prevent further peeling. If the peeling is severe, you may need to reupholster the chair with new leather.
Can I fix a scratch on my computer chair's leather?
Yes, you can fix a scratch on your computer chair's leather by using a leather repair kit or a leather touch-up pen. These products can help to fill in the scratch and blend it with the surrounding leather. Make sure to follow the instructions on the product for best results.
What should I do if the color of my computer chair's leather is fading?
If the color of your computer chair's leather is fading, you can try using a leather dye to restore the color. Make sure to choose a dye that is specifically made for leather and follow the instructions carefully. It is also a good idea to test the dye on a small, inconspicuous area of the chair first.
How can I prevent further damage to my computer chair's leather?
To prevent further damage to your computer chair's leather, make sure to regularly clean and condition the leather. Avoid using harsh chemicals or abrasive cleaners, and keep the chair out of direct sunlight to prevent fading. If possible, try to limit the amount of wear and tear on the chair by using a cushion or protective cover.
