Need help in finding extreme values
  • Thread starter aruwin
In summary, my teacher has written this problem. He has given us hints to find the extreme values of the function, but it is not clear to me what they mean. He also said that if we add the fx + fy terms, we get 4x3 = -4y3, which means x = -y. However, x = 0 √2 or -√2 also satisfies the equation. He has also arbitrarily called these solutions O A and B. At the origin, O, the only solutions are (0,0) and (-√2,√2).
  • #36
haruspex said:
For the purpose of asking whether it's a max etc., the -8 is irrelevant. You don't care what the value of f is there, you only care how the value changes as you move from that point in different directions. If it increases no matter which way you move it's a minimum.
Yes,I was a lil confused before.Now I understand it.
From the quadratic equation that we got from the taylor expansion,-8 is the constant and we have a square and thus, f(x,y)is always going to be bigger or equals to -8 and so we have a minimum value of -8.Am I right?
  • #37
aruwin said:
From the quadratic equation that we got from the Taylor expansion,-8 is the constant and we have a square and thus, f(x,y) is always going to be bigger or equals to -8 and so we have a minimum value of -8. Am I right?
Yes, except that as I mentioned you do have to be careful about the 'or equals' bit.
If there is some path from the point in question along which the first derivative of f is zero then you need to look at the second derivative, and if that is zero then the third derivative, and so on. But at the point (√2, -√2), you don't have that complication. Writing u and v for the x and y distances from that point, the first few terms give you -8 + 8u2 + 2(u+v)2 + 8v2. Any movement away from u = v = 0 will initially increase the value.
  • #38
Since if u=v=0,f(x,y) is -8 and that's why I say f(x,y)is equals to or more than f(sqrt(2),-sqrt(2)). Isn't it so?
  • #39
Yes, but you're missing a key detail. It is not enough that f(x,y) is equal to or exceeds -8 in a neighbourhood of the point. You need that it actually exceeds -8 as soon as you move away from that point.
  • #40
aruwin, you're missing the point
(you're also using bad terminology: that expression is not f, it is an approximation to f, so you should give it a different letter, to show the examiner you understand what you're talking about: i'll use "g" :wink:)
at A, g(A + (x,y)) = -8 + 8x2 + 2(x+y)2 + 8y2
so for all (x,y) ≠ (0,0), g(A + (x,y)) > f(A), so g tells us there is certainly a minimum of f at A
at O, the difficulty was that g(O + (x,y)) = f(O) even for some (x,y) ≠ 0, so g tells us there may be a maximum at O, but we need to check further
  • #41
Oh ok,lets use g for the approximation,then:redface: But first of all,the approximation I got at point A is
f(x,y) ≈ -8 + [10(x - √2)^2 + 4(x - √2)(y + √2) + 10(y + √2)^2]
so,
g(x,y) = -8 + [10(x - √2)^2 + 4(x - √2)(y + √2) + 10(y + √2)^2].
This shows that g always increases above -8,right? But if I substitute (√2,-√2) into (x,y), g becomes -8. That's why I thought that the approximation g(x,y)≥f(A) and isn't this the condition to get a local minimum point? And is it correct that I say -8 is the minimum value at A?
  • #42
(i haven't checked that, but …)
let's rewrite that as:
g(A + (x,y)) = f(A) + 10x2 + 4xy + 10y2
then you need to prove that the 10,4,10 part is always strictly positive …
how would you do that? :smile:
  • #43
By completing the square??
  • #44
yup! :biggrin:
  • #45
tiny-tim said:
yup! :biggrin:
Ok,this is what I got:
g(x,y) = -8 + 10 {[(x - √2)^2 + (1/5)(y + √2)]^2 + (24/25)(y + √2)^2].
Now it's proven that g(x,y) is ≥f(A) ?? And the the minimum value is -8?
  • #46
but there's no xy in that! :redface:
10x2 + 4xy + 10y2
= 10(x-y)2 + 24xy = 10(x+y)2 - 16xy
so it lies strictly between 10(x-y)2 and 10(x+y)2, and so must be positive (unless x= = y = 0) :wink:
(alternatively, use the determinant)
  • #47
10x2 + 4xy + 10y2
Actually,I was completing the square of the taylor polynomial which I stated earlier.
That is,
to this:
So, now it is positive. Can I say that g(x,y)≥f(A) and thus,it has a minimum value of -8?
  • #48
That's all fine except that g(x,y)≥f(A) is not strong enough to make it a minimum. You need g(x,y)>f(A) for all (x,y) ≠ A (in some neighbourhood). This is because g is not f - it's only a local approximation to f (which I'll refer to as gA hereon). If there were some path through A along which gA(x,y) = f(A) then later terms in the Taylor expansion might result in f decreasing along that path. A good example is what happens to this same function at O (if you take away the f ≤ 0 constraint). The Taylor series down to the second derivatives gives gO ≤ f(O), but it's a saddle, not a max.
The expression for gA as a sum of squares does give you what you need. It is stronger than merely gA(x,y)≥f(A).
  • #49
tiny-tim said:
(you mean "stuck" :wink:)
but doesn't your professor want you to use the fxx etc formula? :confused:
If the problem is to find the global max and min on a set, then the second derivative formula, which determines whether a critical point gives a local max, min, or saddle point, is irrelevant. Determine all possible points at whicy max or min can occur, where the gradient is 0 in the interior of the set, or on the boundary, calculate the function values at those points, and see which are max and min.
  • #50
Thanks for all your explanations and patience.Yes,I have solved this question with your help and harupex too.By the wsy,I have a new question.Since it is related to finding local extrema too,I am just going to ask it here.
Given the equation x^2+y^2+3z^2-2xy-2yz=2.Find the local extrema for the function z=f(x,y).What do I do with the equation?
  • #51
What do you get when you take the partial derivatives?
  • #52
Is this ok?
Partial derivative in respect to x is 2x-2y and in respect to y is 4y-2x-2z.
What do I do with z??
  • #53
You want to differentiate z with respect to x and y and can do that using "implicit differentiation" just like you learned in Calculus I.
  • #54
aruwin said:
Is this ok?
Partial derivative of z wrt x is ∂z/∂x, etc. Just treat that as a variable. You can differentiate it partially wrt x again, ∂2z/∂x2, or wrt y: ∂2z/∂x∂y. (Btw, ∂2z/∂x∂y = ∂2z/∂y∂x)
