yungman
- 5,726
- 251
I got tripped up on the voltage regulation design. I just layout and got the pcb back, I am not happy with the result. The application is rather low current of less than 40mA, so I tried to be lazy, use unregulated supply and use a lot of capacitor to filter the ripple out. The problem is
1) The output voltage of the power transformer I bought varies from 50VDC when no load to 44V loading with 30mA.https://www.mouser.com/ProductDetail/530-LP-56-100, I bought 12 of them already so I am stuck with this one.
2) I try to use zener diodes to drop the voltage down to 37V or so. I use 1N5333 3.3V 5W zener. That stupid diode only drop less than 2V at 30mA current!
So between big variation of the output voltage of the transformer and the unpredictable voltage of the zener, I don't feel confident to work of this design anymore. So I am planning to start over again.
I want to use voltage regulator this time. The transformer being at +/-50V at no load, I need both +ve and -ve regulator that can withstand input voltage at least 60V. I have no problem finding LM317HVT that can have +60V input.https://www.digikey.com/product-detail/en/texas-instruments/LM317HVT-NOPB/LM317HVT-NOPB-ND/212662, but I cannot find a negative regulator.
Please advice as I am press for time. Any way to salvage the existing board would be helpful, if not, please advice the easiest way to get the -37V with -50V input regulator. Attached is the schematic of my pcb, the top two circuits are the +/-37V supplies.
Thanks
Thanks
