Need help on laplace transform and PDE
In summary: I need someone who can walk me through it step by step. Please.In summary, you are stuck with two questions and you need help with the Laplace transform. You have a table of Laplace transforms available, but you are lost after rewriting the problem for the step function. You also need help with partial differential equations, but you have not done anything yet.
reverie414
Need urgent help on laplace transform and PDE !
I'm stuck with this 2 questions ...
q1) Using laplace transforms, solve: y" + 4y = r(t), where r(t) = {3sint, 0<t<pi, -3sint, t>pi y(0)=0, y'(0)=3.
this is what i get after rewriting for the step function: 3sint [1-u(t-pi)] + (-3sint)u(t-pi) ... I am lost from then on. :confused:
q2) Using the method of separation of variables, solve the following partial differential equations:
a)yux(subscript)-xuy(subscript)=0
b)ux(subscript)=yuy(subscript)
i'm really at my wits end ... need to submit shortly afterwards. thanks a lot for the help. :smile:
You are at your wit's end but show nothing about what you have tried or what you know? Surely you are not a High School algebra student who has accidently walked into a partial differential equations class!
Don't you have a table of Laplace transforms available? That's the standard method to do such problems. If it is the Laplace transform of a function involving a step function that is bothering you, look at this:
http://www.intmath.com/Laplace/4_lap_laptransunit.php
As far as the partial differential equations are concerned, have you DONE anything at all? "separation of variables" means you try something like u(x,y)= X(x)Y(y). Then ux= Xx Y and uy= XYy. Your first differential equation becomes yXxY- xXYy= 0. Dividing through by xyXY makes the equation Xx/(xX)- Yy/(yY)= 0. Since one part depends only on x and the other only on y, in order to cancel, each must be the same constant:
Xx/(xX)= c and Yy/yY= c so you have the two ordinary differential equations Xx= cxX and Yy= cyY. Exactly what possible values c can have will depend on your initial conditions and the actual solution may be a sum of products of X and Y for different values of c.
i've showed what i attempted as mentioned above. i just really got stuck from there onwards. I've of course tried reading up my textbooks and lecture notes prior to posting. had i fully understand, i wouldn't have posted.
yes i have the laplace transform table and able to do basic inverse laplace transform. what i do not understand is using laplace transform to solve for IVP. an explanation (i can try to work out the answer on my own) about the steps is very much appreciated. thanks for the URL. I am reading it now.
i can't show you what i done for PDE, solely because i do not understand at all.
FAQ: Need help on laplace transform and PDE
What is a Laplace transform?
A Laplace transform is a mathematical operation that converts a function of time into a function of complex frequency. It is used to solve differential equations, particularly in the field of partial differential equations (PDEs).
Why is the Laplace transform useful for solving PDEs?
The Laplace transform reduces the complexity of solving PDEs by transforming them into algebraic equations, which are typically easier to solve. It also allows for the use of well-known mathematical tools and techniques, making the solution process more efficient.
What are the steps for using the Laplace transform to solve a PDE?
The general steps for using the Laplace transform to solve a PDE are as follows:
  1. Take the Laplace transform of both sides of the PDE.
  2. Apply appropriate initial and boundary conditions to the transformed equation.
  3. Solve the resulting algebraic equation for the transformed dependent variable.
  4. Take the inverse Laplace transform to obtain the solution in terms of the original dependent variable.
What are some common applications of the Laplace transform in science and engineering?
The Laplace transform is used in various fields of science and engineering, including electrical engineering, control systems, signal processing, and fluid mechanics. It is particularly useful in solving problems involving systems with time-dependent inputs and outputs.
Where can I find resources for learning more about Laplace transform and PDEs?
There are many online resources available for learning about Laplace transform and PDEs, including textbooks, lecture notes, and video tutorials. You can also consult with your peers and professors for recommendations on specific resources that may be helpful for your learning style.
