Need help sealing my 775DC 30,000 rpm motor shaft
In summary, the seal for a pump with air and water in it that will be running for up to 5 minutes may need less leakage than a labyrinth seal. However, heat and vibration may be a problem.
ausmar1218
TL;DR Summary
30,000 rpm 775DC motor seal.
Hi,
I need help finding a way to seal my 775DC 30,000 rpm 5mm motor shaft going into my pump housing I built. This motor will run once a week for up to 5 minutes. The pump with have air and water in it. I will rarely ever be completely filled with water. So, the pump will mainly be pushing air with some water through it. I have used a dishwasher diverter seal which works, but gets way too hot due to the friction between the seal and shaft. The dishwasher diverted seal’s dimensions are 5.5x16x8mm. I am also playing with the idea of using grease like Bentone grease to try and seal the shaft from the water leaking out of the pump housing. Any suggestions and ideas are welcome! Thanks in advance!
Mark
Welcome, Mark!
Research or look up "pump labyrinth seal 5 mm".
Likes Baluncore
Lnewqban said:
Welcome, Mark!
Great, thank you very much!
Likes Lnewqban
Have you used these seals?
Likes Lnewqban
Baluncore said:
If less leakage than a labyrinth seal is required, consider a polished Ceramic flat face seal as used in water pumps. Small diameters will run continuously at 20,000 RPM.
https://www.aliexpress.com/item/1005005121659359.html
Great, thank you! Have you used these seals before with 20,000rpms?
Not that small. I have used much larger seals of the same type on water pumps, with similar contact surface speeds.
Clean water lubricates and helps seal the flat, polished surface contact.
The static, ceramic part of the seal is usually spring-loaded, while the rotating part is fixed to, and balanced on, the rotating shaft.
Yes, in centrifugal pumps, blowers and steam turbines, but not at those rpm's.
Vibration and heat may be a problem in your application.
Turbochargers for combustion engines spin very fast and need to be very carefully balanced.
I don't believe that grease will help in your case.
The above suggestion from @Baluncore is excellent.
Yes, I’m just worried with the high rpms and not having water in the pump chamber all the time even when the pump is running for up to 5 minutes that heat from friction will be a problem.
Does your use require the motor to be actually submerged?
If not, a magnetic coupling is a possibility so the motor can be kept in the atmosphere.
Depending on the design details, note that a magnetic coupling may require a slow start of the motor to gradually bring the pump up to speed.
Cheers,
Tom
Likes Lnewqban
Cheers,
Tom
Hi Tom,
Thank you very much for the input! No, my motor is not submerged. My motor doesn’t have a slow start and I’m not sure how the magnetic coupling would affect the torque or if something is clogging the impeller. I will look into it. Thank you very much!
FAQ: Need help sealing my 775DC 30,000 rpm motor shaft
What type of seal should I use for my 775DC motor shaft?
For a 775DC motor shaft, it's recommended to use a rubber or silicone O-ring seal that can withstand high speeds and temperatures. Ensure the seal fits snugly into the housing to prevent any leakage of lubricants or contaminants.
How do I properly install the seal on the motor shaft?
To install the seal, first clean the shaft and the housing to remove any debris. Slide the seal onto the shaft carefully, ensuring it is aligned properly. Use a seal installation tool or a soft mallet to gently press the seal into the housing without damaging it.
Can I use adhesive to seal the motor shaft?
While some adhesives can provide additional sealing, it is generally not recommended for motor shafts due to the potential for adhesive failure under high speed and heat. Instead, rely on mechanical seals or O-rings designed for this application.
What maintenance is required to keep the seal effective?
Regularly inspect the seal for wear, cracks, or signs of degradation. Clean the area around the seal to prevent dirt buildup, and replace the seal if you notice any leaks or if it appears damaged.
How can I prevent overheating of the motor shaft seal?
To prevent overheating, ensure that the motor is not overloaded and that it has adequate cooling. Use a seal material rated for higher temperatures, and consider adding ventilation to the motor housing to dissipate heat effectively.
