Need help solving this trig equation
In summary, the best approach to solving the equation 3cos(θ) + 1.595*sin(θ) = 3.114 is to use the identity (sinθ)^2 + (cosθ)^2 = 1 and solve for sinθ, then substitute it into the equation and solve for θ. Another approach is to use the identity a cosθ + b sinθ = √(a^2 + b^2) cos(θ-φ) where tanφ = b/a, and solve for θ using this formula.
flgdx
what's the best way to solve this equation: 3cos(θ) + 1.595*sin(θ) = 3.114
I tried using the identity above to solve this equation and ended up with cosθ = +/- 1.0526.
Could you show your steps for your solution?
so since (sinθ)^2 + (cosθ)^2 = 1, I solved for sinθ and got sqrt(1 - (cosθ)^2). Then I subtituted it into the equation 3cos(θ) + 1.595*sin(θ) = 3.114 and solved for θ.
Well, that's obviously wrong because -1 ≤ cos θ ≤ 1, and 1.0526 is outside that range. Your approach should work though.
$$a \cos\theta + b \sin\theta = \sqrt{a^2+b^2} \cos(\theta-\phi)$$ where ##\tan\phi = b/a##.
could you pls show me how you got that equation?
Consider a right triangle below and use the identity ##\cos(\theta-\phi) = \cos\theta\,\cos\phi + \sin\theta\,\sin\phi##.
Related to Need help solving this trig equation
What is a trig equation?
A trigonometric equation is an equation that involves trigonometric functions such as sine, cosine, tangent, etc. The goal is to solve for the unknown variable using trigonometric identities and properties.
What are the common trigonometric identities used to solve equations?
The most common identities used are the Pythagorean identities, sum and difference identities, double angle identities, and half angle identities. These identities help simplify equations and solve for the unknown variable.
How do I solve a trig equation?
To solve a trigonometric equation, you must isolate the unknown variable and use trigonometric identities to simplify the equation. Then, you can use inverse trigonometric functions or a calculator to find the value of the unknown variable.
What are the steps to solve a trig equation?
The steps to solve a trigonometric equation are:
1. Isolate the unknown variable on one side of the equation.
2. Use trigonometric identities to simplify the equation.
3. Use inverse trigonometric functions or a calculator to find the value of the unknown variable.
What are some tips for solving tricky trig equations?
Some tips for solving tricky trigonometric equations are:
1. Memorize common trigonometric identities.
2. Use substitution to simplify complex expressions.
3. Check your answers by plugging them back into the original equation.
4. Practice, practice, practice!
