Need help to prove this Identity
  • Thread starter klmathlover
  • Tags
    Identity
In summary: Sometimes you have to try different things out, but it boils down to multiplying a + b by a - b to get a2 - b2, or multiplying a - b by a + b to get the same thing, to see if that gets you anywhere. With those squared terms I was hoping to get sin2(x) + cos2(x), which I can replace by 1.
klmathlover
Help! I spent 3 hours attempting this question. Prove the following identity :
(tan x + sec x -1) / (tan x - sec x + 1) = tan x + sec x
I've simplified Left Hand Side into cos and sine. Which ended up like this
(sine x - cos x + 1) / (sine x + cos x -1)
Then I'm stuck.
Any help is very much appreciated!
Then I'm stuck.
So far, so good.
Edit: changed a sign in numerator and denominator, below.
Now multiply by 1 in the form of (sin x + cos x + 1)/(sin x + cos x + 1). Remember the identity sin2x + cos2x = 1.
Hi there, thanks a lot for your quick reply.
I've done the multiplication and now I ended up with (sin^2 x - cos^2 x - 1) / (2 + 2sinxcosx -2sinx)
I tried to further simplify into sin^2 x - 1 / 1 + sinxcosx - sin x, but then I'm stuck here.. wondering if this is the correct method.
Thanks in advance!
Sorry, I steered you wrong. My scratch work was correct but I copied a sign incorrectly in my post. The left side of the identity is equal to (sin x + 1 - cos x)/(sin x - 1 + cos x), which equals (sin x - cos x + 1)/(sin x + cos x - 1). Multiply this expression by 1 in the form of (sin x + cos x + 1)/(sin x + cos x + 1).
Thanks - I've got it. :)
May I ask you - how do you know what to do with this question in the first place? I mean, how do you know to mulitply by one (which I understand and make sense) but how to do you what to multiply with?
I mean it could be sinx + cosx +1 or sinx - cos x + 1 or any other combination.
Do you have a specific method or have to try out one by one?
In your problem, there was (sin x - cos x + 1)/(sin x + cos x - 1), so I looked at the denominator as a difference, (sin x + cos x) - 1, and thought multiplying by a sum, (sin x + cos x) + 1 might be useful. If that hadn't borne fruit, I would have tried a similar thing with the numerator. Of course, I can't just multiply the denominator or numerator alone, but I can always multiply by 1.
Partly it's a matter of experience, and seeing the kinds of things that worked in other problems.
Thanks a lot. I can understand now. :)
It's generally a lot easier to simplify the equation as a whole, rather than try and work with the two sides independently.
FAQ: Need help to prove this Identity
What is an identity in mathematics?
An identity in mathematics is an equation that is always true, regardless of the values of the variables involved. This means that both sides of the equation are equivalent to each other, and the equation holds true for all possible values of the variables.
How do you prove an identity?
To prove an identity, you must show that both sides of the equation are equivalent to each other. This can be done by using algebraic manipulations, properties of equality, or known identities. You must also ensure that the steps you take to manipulate the equation are valid and do not change the overall meaning of the equation.
What are some common identities in mathematics?
Some common identities in mathematics include the Pythagorean identity, which relates the sides of a right triangle, and the double angle identities, which involve trigonometric functions. Other commonly used identities include the distributive property, the commutative property, and the associative property.
Why is it important to prove an identity?
Proving an identity is important because it allows us to verify the validity of an equation and understand the relationship between different mathematical expressions. It also helps us to better understand the properties and rules of algebra, and can be used to solve more complex mathematical problems.
What are some tips for proving an identity effectively?
Some tips for proving an identity effectively include starting with the more complex side of the equation, breaking down the equation into smaller, more manageable steps, and using known identities or properties to simplify the equation. It is also important to double-check your work and make sure that all of your steps are valid and lead to an equivalent equation.
