I Need help understanding base-10 number format please
  • I
  • Thread starter Thread starter andrecoelho
The discussion centers on the representation of the number 9312 in base-10 format, specifically how to interpret the term 10^2. Participants clarify that 10^2 equals 100, not 2 or 1000, and express that logarithms are unnecessary for this calculation. The conversation emphasizes that 9312 can be broken down into its components: 9*1000 + 3*100 + 1*10 + 2. The importance of clear mathematical expression is highlighted to avoid confusion. Understanding base-10 representation does not require logarithmic functions.
andrecoelho
Hey..suppose i have the 9312 number. And 3 digit. Number can be represented by
9*10^3 + 3*10^2 + 1*10 + 2
how do i get the 10^2 ? (either 2 or 1000) ? do we need logarithms?
thanks
andre
Mathematics news on Phys.org
Hi, @andrecoelho, first of all, wellcome.
They first sentence stands for four digits. What do you mean when you mention three digits?
Fine
From my point of view, it is ten powered to two. I see no mathematical difficulty.
My opinion is that it is either ##100## or ##10^2##. Why should we need logarithms?. Logarithms are the opposite function to exponentiation.
Which is the question you want to solve?
Greetings!
Likes e_jane and berkeman
Not sure what you’re asking but perhaps by rewriting what you wrote will clarify what you want?
9312 is short for ##9*1000 + 3*100 + 1*10 + 2##
we can use various math expressions to get the units value
##9312 - INT( 9312 / 10 )*10 = 9312 - INT( 931.2 )*10 = 9312 - 9310 = 2##
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
