Need Help Understanding Bohr Model Equations
In summary: E=-R(little h)/n^2R(little h) is Rydeberg constant for hydrogen right. N= principal quantum #the value of zero was assigned to the state at which the e- and proton were separated completely. this makes sense since the bigger the n value is= the further orbit it is away from the proton= the closer the E gets to zero. now i do not quite understand two things. Why the negative sign?? and E denotes the energy of the e- right. what exactly does this energy do or mean for the electron?The energy of the electron is negative because it is giving up energy to move from one orbit to another.
jcmartinez
Bohr incorporates Plancks's quantum theory into his model, placing conditions on the value of the angular momentum.
angular momentum = nh/2pi
n=principal quantum number h= Planck's constant
since its giving me the angular momentum, is it actually giving me a number that corresponds to an orbital. s,p,d, or f?
Bohr then equated the allowed values of the angular momentum to the energy of the e-. He obtained the folowing equation:
E=-R(little h)/n^2
using this formula E=13.6-(13.6/n^2)
E = energy
n= energy level.
using that formula Bohr predicted the energy levels for each of the allowable orbits in the Hydrogen atom.
now i would like to understand why 13.6 is used?
and what does this information actually tell us.
please help as best you can. i have tried reading things up on Wikipedia but that does not help me much.
Chemistry news on Phys.org
E=-R(little h)/n^2
E = energy
n= energy level.
The value of 13.6 is just reflective of a choice of units. The particular choice in this case is known as an electron-volt, which is defined as the amount of kinetic energy gained by an electron when it is accelerated through a potential of one volt. You can convert it into whatever energy units you want .. in joules the 13.6 eV amounts to about 2.18x10-18 J. This energy corresponds to the ground state energy of the H-atom .. the highest possible amount of energy by which an electron can be bound to an H-atom nucleus. This quantity is also called the ionization energy of the atom, because (by conservation of energy) it is also the amount of energy that you need to add to the atom in order to remove the electron.
I think the Bohr model as you have expounded it corresponds only to the
s orbitals. The others were dealt with by Sommerfeld who made their orbitals elliptical. They did not work completely but their predictions were tantalisingly near.
Related to Need Help Understanding Bohr Model Equations
1. What is the Bohr Model?
The Bohr Model, also known as the Bohr-Rutherford Model, is a simplified representation of the atomic structure proposed by Danish physicist Niels Bohr in 1913. It describes the atom as a small, positively charged nucleus surrounded by orbiting electrons at specific energy levels.
2. How are electrons arranged in the Bohr Model?
In the Bohr Model, electrons are arranged in circular orbits around the nucleus at specific energy levels or shells. The innermost shell can hold up to 2 electrons, while the second and third shells can hold up to 8 electrons each.
3. What is the equation for calculating the energy of an electron in the Bohr Model?
The equation for calculating the energy of an electron in the Bohr Model is E = -13.6 eV/n^2, where E is the energy, n is the principal quantum number, and eV is the unit for energy called electron volt.
4. How does the Bohr Model explain the emission and absorption of light by atoms?
The Bohr Model explains the emission and absorption of light by atoms through the concept of electron transitions between energy levels. When an electron absorbs energy, it moves to a higher energy level. When it falls back to a lower energy level, it releases the extra energy in the form of light.
5. What are the limitations of the Bohr Model?
The Bohr Model has several limitations, including the inability to explain the shape of atomic orbitals and the phenomenon of electron spin. It also does not account for the uncertainty principle or the concept of wave-particle duality. However, it is still a useful model for understanding the basic structure of atoms.
  • Chemistry
