Need help understanding Euler's formula (complex numbers)
In summary, the conversation discusses the notation and evaluation of Euler's formula. The first question asks about the notation of ei\vartheta and the second question asks about the use of variables in the formula. The concept of defining exponents for complex numbers is explained, along with the use of Taylor's series to define eA for other mathematical objects like matrices. The conversation concludes with the recognition of cosine and sine in the Taylor's series as the real and imaginary parts of e^{ix}.
dmehling
114
I have a couple questions regarding Euler's formula. First I'm confused about the notation ei[tex]\vartheta[/tex]. To me the notation implies that we are raising e to the exponent i multiplied by [tex]\vartheta[/tex]. Is this correct? If so, how would you do that? Also, my second question regards the second part of that equation: cos[tex]\vartheta[/tex] + isin[tex]\vartheta[/tex]. That makes sense to me, but sometimes I see it written as cosx + isinx. I don't understand what that means. What would be the cosine or sine of x?
You seemed to be confused about mathematical notation. eix= cosx+isinx is a relationship where x is a dummy symbol. You can plug in any value (make sure you understand the trig function arguments are radians, not degrees) on both sides and the relationship holds. It doesn't matter what symbol you use as long as it is the same for all three functions.
Thanks for answering my second question. I didn't realize that variables could be used to stand in for something like an angle. I figured that simply using theta would suffice as a variable of sorts.
What about my first question? Is the first part of the formula an exponential expression or not, or is this an expression that cannot be evaluated?
You can't really define the exponent of a complex number.
This formula can be derived by several tools, but the use of these tool in the field of complex number is not rigorous: you can't really prove that they behave the same in the complex field as they in the real field (just like the exponent itself), so this formula remains more like a definition rather than a theorem.
elibj123, everything in mathematics is "rigorous". We can and do "really define the exponent of a complex number".
You can define exponentials or things other than regular real numbers, not just imaginary numbers and complex numbers, but matrices, etc. by using the Taylor's series.
It is shown in calculus that the power series
[tex]\sum_{n=0}^\infty \frac{x^n}{n!}= 1+ x+ \frac{1}{2}x^2+ \frac{1}{3!}x^3+ \cdot\cdot\cdot[/itex]
converges to ex for all x.
Since that involves only products and sums, we can use that to define eA for anything we can define products and sums for (including complex numbers and matrices, etc.).
In particular, we know that [itex](ix)^2= i^2x^2= -x[/itex], [itex](ix)^3= (ix)^2(ix)= (-x)(ix)= -ix^3[/itex], and [itex](ix)^4= (ix)^3(ix)= (-ix^3)(ix)= -(i^2)x^4= x^4[/itex]. Of course, higher powers just repeat that. In particular:
[tex]e^{ix}= 1+ (ix)+ \frac{1}{2}(ix)^2+ \frac{1}{3!}(ix)^3+ \frac{1}{4!}x^4+ \frac{1}{5!}(ix)^5 \cdot\cdot\cdot[/tex]
[tex]= 1+ ix- \frac{1}{2}(-x^2)+ \frac{1}{3!}(-ix^3)+ \frac{1}{4}(x^4}+ \frac{1}{5!}ix^5+ \cdot\cdot\cdot[/tex]
We can divide that into "real" and "imaginary" parts:
[tex]e^{ix}= (1- \frac{1}{2}x^2+ \frac{1}{4!}x^4-\cdot\cdot\cdot)+ i(x- \frac{1}{3!}x^4+ \frac{1}{5!}x^5+\cdot\cdot\cdot[/tex]
and recognize those as the Taylor's series for cosine and sine:
[tex]e^{ix}= cos(x)+ i sin(x)[/tex].
FAQ: Need help understanding Euler's formula (complex numbers)
What is Euler's formula?
Euler's formula is a mathematical equation that relates complex numbers to trigonometric functions. It is written as e^ix = cos(x) + i*sin(x), where e is the base of the natural logarithm, i is the imaginary unit, and x is the angle in radians.
How is Euler's formula used?
Euler's formula is often used in complex analysis and other areas of mathematics to simplify calculations involving complex numbers. It also has applications in physics and engineering, particularly in the study of oscillations and waves.
What is the significance of Euler's formula?
Euler's formula is significant because it provides a powerful connection between exponential functions and trigonometric functions. It also highlights the fundamental relationship between complex numbers and the unit circle, which has many important implications in mathematics.
Can you explain the intuition behind Euler's formula?
Euler's formula can be understood intuitively by visualizing the unit circle in the complex plane. As the angle x increases, the point on the unit circle moves counterclockwise, tracing out the cosine and sine values along the real and imaginary axes, respectively. The exponential term e^ix represents the radius of the unit circle, and thus, the magnitude of the complex number.
Are there any real-life examples of Euler's formula?
Yes, Euler's formula has applications in many real-life situations, such as analyzing the behavior of electrical circuits, modeling the spread of diseases, and understanding the properties of sound and light waves. It is also used in computer graphics to rotate and scale 2D and 3D objects.
