Need help understanding logarithmic properties
In summary: I must have made a mistake, thanks for pointing it out!In summary, log is the inverse of exponentiation and can be written as log_a(x) = a^x. In order for the "10" coefficient and 'log' to disappear in an equation, the base of the log must match the base of the exponentiation. This can be shown by the formula log_ax = log_bx / log_ba. Understanding this relationship can help in solving problems involving logarithms.
daigo
27
Okay, so in class I learned that:
10^log(4x) = 4x
But I don't understand why.
I get that a log without a subscript is considered base 10, so:
10^y = 4x
Is the way to understand "log(4x)", right?
What if the problem was a different base? Would the "10" coefficient and 'log' in the original problem disappear also? If not, what coefficient would it have to be to match the base log in order for those to disappear?
Mathematics news on Phys.org
10^log(4x) = 4x
Well, log(4x) is the power that you raise 10 to in order to get 4x.
And then you do it ... you raise 10 to that power ... so that 10^log(4x) = 4x.
In other words, log(4x) is some quantity that IF you raised 10 to that power, you'd get 4x. And then you raise 10 to that power.
A more sophisticated way of understanding this is that taking a log (with respect to some base) and raising that base to a power, are operations that are inverse to one another.
Keep doing problems, this will become clear with practice.
It has to be the same base. So 3^(log_3(x)) = x
where log_3 is the base-3 logarithm.
Because log_3(x) is the power you'd have to raise 3 to in order to get x; and then you raise 3 to that power, so you get x.
Thanks, this part is what actually helped me understand it after plugging in values:
3^(log_3(x)) = x
3^(log_3(9)) = 9
3^(log_3(9) = [3^?=9]) = 9
3^(log_3(9) = 2) = 9
3^2 = 9
9 = 9
hi daigo! :smile:
you seem to have difficulty in understanding equations :redface:
some equations are definitions, and you just have to learn them
here's a formula that may help in this case, and is easy to visualise and remember …
##\log_ax = \frac{\log x}{\log a} = \frac{ln(x)}{ln(a)} = \frac{\log_bx}{\log_ba}## for any bases a and b :wink:
(and, as you know, alogax = x by definition)
If it helps, think about the log function as what it is - the inverse of exponentiation, by that I mean;
if we define [itex]f(x)=10^x[/itex], then [itex]log(x)=f^{-1}(x)[/itex], and by the definition of an inverse [itex]f^{-1}(f(x)) = x[/itex]
To give you a few examples take;
[itex]f(2) = 10^2 = 1000[/itex]
so [itex]log(1000) = f^{-1}(1000) = 2[/itex]
[itex]f(3.5) = 10^{3.5} = 3162.28[/itex]
so [itex]log(3162.28) = f^{-1}(3162.28) = 3.5[/itex]
When I started learning about logs understanding that it's just an inverse is what got it to 'click' for me. It's then easy to remember the things like log[a b] = log[a]log since they just come straight from the fact that 10^a 10^b = 10^(a+b)
For any positive number, a, [itex]log_a(a^x)= x[/itex] and [itex]a^{log_a(x)}= x[/itex]. Those essentially follow from the fact that "[itex]log_a(x)[/itex]" and "a^x[/itex] are inverse functions.
I'm sure this was a typo but [itex]10^2= 100[/itex], not 1000.
yes haha, I was pretty tired when I typed that
FAQ: Need help understanding logarithmic properties
What are logarithmic properties?
Logarithmic properties are mathematical rules that describe the behavior of logarithmic functions. Logarithmic functions are the inverse of exponential functions and are used to solve equations involving exponential growth or decay.
What is the product property of logarithms?
The product property of logarithms states that the logarithm of the product of two numbers is equal to the sum of the logarithms of each individual number. This can be written as logb(xy) = logb(x) + logb(y).
What is the quotient property of logarithms?
The quotient property of logarithms states that the logarithm of the quotient of two numbers is equal to the difference of the logarithms of each individual number. This can be written as logb(x/y) = logb(x) - logb(y).
What is the power property of logarithms?
The power property of logarithms states that the logarithm of a number raised to a power is equal to the product of the exponent and the logarithm of the number. This can be written as logb(xn) = n * logb(x).
How do logarithmic properties help in solving equations?
Logarithmic properties allow us to simplify and manipulate equations involving logarithmic functions, making them easier to solve. These properties also help us to convert between different bases of logarithms, which can be useful in certain applications.
