Need help understanding ray optics question
In summary, the conversation discusses the reasoning behind the answer to a question about diffraction and interference patterns created by an aperture and slit. The answer is C because the aperture blocks most light, and the lamp bulb's shape affects the resulting pattern. The conversation also touches on the concept of a point source and its appearance on the screen.
Woah_Moses
http://i.imgur.com/q6EaspT.png
2. The attempt at a solution
why is the answer C? shouldn't the aperture in front of the screen create a shadow that blocks all the light except the rays that go through slit? (the width of the slit is >>>1mm so it won't make a diffraction pattern.)
You will get diffraction through the slit but no interference pattern because the light is not coherent.
The answer is C , BECAUSE the aperature blocks all light except the (straight, essentially not diffracted) rays that pass thru the slit.
Did you notice that the lamp bulb was horizontally long (rather than tall)?
[that is, what would a "point source" look like on the screen? ...]
Related to Need help understanding ray optics question
1. What is ray optics?
Ray optics is the study of light as it travels in a straight line, or ray, and interacts with different materials and surfaces.
2. How does refraction occur in ray optics?
Refraction occurs when light travels through a material with a different optical density, causing the light to bend and change direction.
3. What is the difference between reflection and refraction?
Reflection occurs when light bounces off a surface without changing direction, while refraction involves light changing direction as it passes through a material.
4. How does the shape of a lens affect the path of light in ray optics?
The shape of a lens determines how it bends and focuses light. Convex lenses converge light towards a focal point, while concave lenses diverge light away from a focal point.
5. How can ray optics be applied in everyday life?
Ray optics is used in various technologies such as cameras, telescopes, and corrective lenses for vision. Understanding ray optics can also help explain everyday phenomena such as rainbows and mirages.
