Need Help With a Few Basic Electrical Questions
  • Thread starter gbeach01
  • Tags
    Electrical
In summary, the conversation discusses three different problems, one involving Ohm's law, another involving transistors, and the third involving an oscilloscope. The conversation also includes hints and suggestions for solving each problem, such as researching and studying relevant concepts and equations.
gbeach01
Hi All
It's been years since I've had to do any of these sort of problems and I've forgotten how to do these types of problems so I'm hoping one of you smart people can help. As much detail as possable please
First Question
I fairly certain I need to use ohm's law on this one but can't seem to figure it out. I need to know the voltage at point A?
Second Question
Could someone please explain to me what the characteristics and configuration of the following transistors?
Third Question
What will you observe on the screen of the oscilloscope at points A,B,C (I need the wave forms and voltages please)
Welcome to PF, gbeach01. It is not the policy at PF to simply supply answers to questions until the poster has researched the problem and has attempted to solve itr. Read up on ohm's law and parallel and series resistances for the first one. You'll need to study transistors for the second, and semiconductor device operation as well as reactive circuits for the third. You are welcome to come back with questions about specific points where you get stuck.
For the first question, what is the relationship between the two vertical resistors that are connected to ground?
The second question involves a so called "Darlington Pair," which you can look up.
Thanks for the reply I think problem one is a trick question I think the two parallel resistors have nothing to do with the problem cause correct me if I'm wrong electricity takes the path of least resistance. So to find the voltage at a I would use the equation V = I x R where I = 1ma and R = 10 so the answer would still be 10V at A correct or am I way off. Oh and I don't even know where to start with question 3 anyone have any hints.
Problem 1: Think of the point A as not even being there. It's part of the node where the current splits between the two 10K resistors, it's just there to show you where the voltage is being taken at.
Then you can easily find the current through the entire circuit by combining the parallel resistors, then combining that with the series resistor, finding the current, and finding the voltage drop across the first 10K resistor for the voltage at node A. (It's not 10V.)
Problem 2: I know nothing about BJTs.
Problem 3: You have two regular diodes and a zener diode. Regular diodes operate by allowing current through if the diode is forward biased (current flowing from base of triangle to tip of triangle), and they have a voltage drop of approximately 0.7V. The last diode is a zener diode. These are specifically made to operate in the reverse bias region, I forget the specifics but a small change in current amounts to a big change in voltage is what these basically do.
I don't remember the specifics for circuit analysis with zener diodes though...
The capacitor I think acts as a short if your frequency is not too high or not too low (mid-band).
Hints for problem three...
a) Temporarily pretend the 1K resistor and the zenner diode aren't there...
b) The two ordinary diodes on the left will conduct if the left hand side is more than 0.7V higher voltage than the right . So when Vin = +50V point A cannot be lower than ?. Likewise point B and the capacitor voltage cannot be lower than ?.
c) So knowing that the voltage on the capacitor is the value calculated in b) ... what happens if Vin suddenly falls to -50V ?
d) Once you have figured out what happens to the voltage on the capacitor add back the resistor and the zenner.
FAQ: Need Help With a Few Basic Electrical Questions
What are the basic principles of electricity?
Electricity is the flow of electric charge, typically carried by electrons. It is created when electrons are able to move from one atom to another. This flow of electrons is known as an electric current.
How do I know if my electrical wiring is safe?
You can hire a licensed electrician to conduct an electrical safety inspection. They will check for any potential hazards, such as faulty wiring or overloaded circuits, and make recommendations for repairs or upgrades.
What is the difference between AC and DC electricity?
AC (alternating current) electricity changes direction periodically, while DC (direct current) electricity flows in only one direction. AC is typically used for household appliances, while DC is used for electronics and battery-powered devices.
How do I troubleshoot an electrical problem?
Start by checking the circuit breaker or fuse box to make sure the circuit has not been tripped or blown. If that is not the issue, unplug any appliances or devices that may be causing the problem and then try resetting the circuit. If the issue persists, it is best to call a professional electrician for assistance.
What safety precautions should I take when working with electricity?
Always turn off the power to the circuit before working on any electrical component. Use tools with insulated handles and avoid using metal ladders or working in wet conditions. If you are unsure about how to safely complete a task, it is best to hire a professional electrician.
