Need help with friction question
  • Thread starter nimboman
  • Tags
    Friction
In summary, a steel washer is suspended inside an empty shipping crate from a light string attached to the top of the crate. The crate, with a mass of 172kg, slides down a long ramp that is inclined at an angle of 34degrees above the horizontal. The person sitting inside the crate has a mass of 67kg. As the crate slides down the ramp, the washer is at rest with respect to the crate when the string makes an angle of 59degrees with the top of the crate. The question is asking for the coefficient of the kinetic friction between the crate and the ramp. To find this, we need to take into account the forces acting on the box and the washer. By setting up equations and solving for the
nimboman
A steel washer is suspended inside an empty shipping crate from a light string attached to the top of the crate. The crate slides down a long ramp that is inclined at an angle of 34degrees above the horizontal. The crate has mass 172kg. You are sitting inside the crate (with a flashlight); your mass is 67 kg. As the crate is sliding down the ramp, you find the washer is at rest with respect to the crate when the string makes an angle of 59degrees with the top of the crate.
What is the kinetic coefficient of the friction between the crate and the ramp?
Is the mass of the observing person already included in the listed mass of the crate?
nimboman said:
You are sitting inside the crate (with a flashlight); your mass is 67 kg. .
Does that answer your question about the observing person being listed in the mass of the crate?
Actually, it's still ambiguous to me. Does it mean that the crate is 172 kg with the person in there, or that the crate itself weighs 172 kg and then the person's 67 kg needs to be added in there for a grand total of 239 kg?
I believe the 172kg does not include the mass of the person.
But in any case, what's the question?
Sorry forgot to post the question. The question is what is the kinetic coefficient between the crate and the ramp
If the crate was moving at a constant velocity then the washer would hang straight down relative to the world outside the crate, or at 34 degrees to the roof of the crate. It's not, however, so the crate is accelerating in some way.
Note that the question doesn't make it clear in which direction the washer is hanging, but that doesn't matter...if it's one way then the crate is accelerating, if it's the other then it's decelerating, either way the coefficient of friction remains the same.
What have you got so far?
i don't really know how to start. need some enlightment!
The forum rules say you have to make an attempt before clues can be posted...got any ideas at all? Doesn't matter if they're wrong, the whole point of science is that being wrong is just fine as long as you can work out why you're wrong.
ok i suppose i can find the force acting parallel to the ramp when the crate is not moving.
which is (mass of crate + mass of me)*sin34*g. I'm not sure how to calculate the force when frictional force is taken into account. since friction is equivalent to normal force*friction coefficient, in this case, friction force=mgsin34*friction coefficient.
oh wait, frictonal force will actually affect the normal force. so i can't use 34 as the angle
Nope, right first time. The frictional force is there as well as the force parallel to the ramp. One counteracts the other. It's the difference between the two forces you need to look at. You've got a mass for the crate, you've got an acceleration for the crate (or, at least, you've got a pendulum...)...
anyway, when the crate is moving with frictional force taken into account. the force parallel to the ramp is it mgcos59? so the frictional force is just mgcos34 - mgcos59?
but now i equate this frictional force to mgsin(theta)*friction coefficient. in this case i 34 for theta or 59?
sorry if i phrased the question wrongly. the question is asking for the coefficient of the kinetic friction. so in this case we only take into account friction when the crate is moving
My point was that with kinetic friction, there's a certain, special coefficient that will balance the acceleration due to gravity and leave the crate with a constant velocity down the slope.
But the washer is hanging at an angle, so there's an acceleration. We're not at the special, balanced coefficient.
How big the acceleration is (in terms of g), and therefore the coefficient of friction, is related to the angle the washer hangs at.
Soln:
Considering the Box:
Let M be combined mass, u be Fk coeff.
//Slope: Fx = Mgsin34 - uMgcos34 = Ma
Considering the Steel Washer:
Let m be mass of Steel Washer, T be tension in the string
Perpendicular to slope: Fy = Tsin59 - mgcos34 = 0
//Slope: Fx = Tcos59 + mgsin34 = ma
So combine the above 2 eqns: you get value of a.
Substitute a into first eqn and you'll get u. Hope this helps.
hey thanks for ur help. i got it. ur from ntu aero?
FAQ: Need help with friction question
What is friction?
Friction is the force that resists motion between two surfaces that are in contact with each other. It can be caused by various factors such as roughness, adhesion, and deformation of the surfaces.
Why is friction important?
Friction plays a crucial role in our everyday lives. It allows us to walk without slipping, enables car tires to grip the road, and helps us grip objects. Without friction, it would be challenging to control the motion of objects and perform tasks efficiently.
How is friction calculated?
The force of friction is calculated by multiplying the coefficient of friction (a measure of how much two surfaces grip each other) by the normal force (the force exerted by one object on another). The formula for friction is F = μN, where F is the force of friction, μ is the coefficient of friction, and N is the normal force.
What are the different types of friction?
There are three main types of friction: static, kinetic, and rolling. Static friction occurs when two surfaces are not moving relative to each other, kinetic friction occurs when two surfaces are sliding against each other, and rolling friction occurs when an object is rolling on a surface.
How can friction be reduced?
Friction can be reduced by using lubricants such as oil or grease, which create a layer between two surfaces and reduce the amount of friction. Another way to reduce friction is by using smoother surfaces or by adding wheels or ball bearings to objects to reduce the surface area in contact with the ground.
