Need help with PIN diode selection in RF switching circuit
  • Thread starter Thread starter James Demers
    Diode Rf Rfid
A project requires activating a passive RFID tag using a PIN diode in the antenna loop to block RF signals unless a forward DC voltage is applied. However, the discussion highlights that RFID tags derive power by rectifying antenna voltage, complicating the insertion of additional components. It is suggested that understanding the specific circuit of the RFID tag is crucial before making modifications. Alternatives like FET or CMOS switches are recommended for low-power applications. Overall, programming the RFID tag for enabling or disabling transmission may be a more effective solution.
James Demers
TL;DR Summary
Can I make a passive RFID tag switchable, by inserting a PIN diode into the antenna loop?
I have a project that calls for activating a passive RFID tag by applying a few volts, and a PIN diode seems to be what I need. I can insert it into the antenna loop, where it would prevent an RF signal from being sent unless a forward DC voltage was present. I only know enough about electronics to be dangerous, and I'm hoping somebody can advise me on the appropriate specs for the diode. The spec sheets for these things are baffling: https://rocelec.widen.net/view/pdf/wkwnaj16jm/INFNS15694-1.pdf and there's not a lot of info on low-power applications like mine. (We're talking about the inexpensive 13.56 MHz stick-on tags that they put on retail products.)
Any help would be much appreciated!
James Demers said:
TL;DR Summary: Can I make a passive RFID tag switchable, by inserting a PIN diode into the antenna loop?
I think you would find the following article helpful. It might be worth considering an FET or CMOS switch for your task as it consumes little power. https://www.digikey.co.uk/en/articl...kGKgjdRRFSKTevpNJAEGdnC5vqDhNQROEnxBRqI5Q9OFc
You are approaching this from the wrong direction. The RFID tag derives power by rectifying the antenna voltage. It uses diodes to do that. You will need to know the circuit used by your RFID tag before you insert further components in that circuit.
The PIN diodes used in RF switches usually come in pairs. When one is reverse biased, the other is forward conducting. That way, when one diode blocks current, the other allows the signal to pass. That requires a continuous forward voltage or current. Meanwhile, given a sufficiently high RF voltage, your disabling voltage will be exceeded, and the RFID tag will become active.
You might do better by programming a tag to enable or disable transmit.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
