Need help with Projectile Motion Questions
In summary, the shell will land on top of the tank if the tank is in motion and the muzzle velocity of the gun is the same as the tank's horizontal speed.
lilmase
I need some help explaining these concepts
1. Suppose a tank is able to point its barrel up at an angle of 90o. If the tank is in motion and fires a shell straight up, where will the shell land if the tank maintains a constant motion. (don't consider any air resistance) a) in front of the tank b) behind the tank c) on top of the tank
2. Suppose an airplane drops a package out of its cargo hold while it is traveling through the sky with a constant horizontal speed. Where will the package land once it hits the ground? a) directly below the plane b) below the plane and ahead of it c) below the plane and behind it
My explanations
1. C. Because the shell does not accelerate in the x-direction and... (i'm lost here)
2. A. (Not sure why, intuitively I can see why it happens but cannot explain why)
Thanks.
The shell has an initial velocity, and that initial velocity has ##x## and ##y## components. They are:
##v_x =## the horizontal velocity of the tank
##v_y =## whatever the muzzle velocity of the gun is
Neglecting air resistance, the equations of motion for the shell can be found by using ##\mathbf{F} = m \mathbf{a}##. The equations are: ##\frac{d}{dt}v_x = 0## and ##\frac{d}{dt}v_y = - g##
Or, in words: ##v_x## stays constant because the ##x##-component of force on the shell is zero. But the ##y##-component of force is ##-mg##, so the shell has a ##y##-acceleration of ##-g##. (I'm assuming you've defined the positive ##y##-direction to be "up.") Gravity makes ##v_y## drop to zero, then become negative, then become really negative. But throughout its flight, the shell still has the same ##v_x## as the tank. So if the tank doesn't turn or change speed, it will be hit by its own shell.
If we neglect air resistance, it's a similar problem: the ##v_x## component of the package is constant until it hits the ground. (The ##x##-component of gravity is zero, and there are no other forces, so its ##x##-acceleration is zero.) If the ##v_x## component of the airplane also stays constant, the package will land directly under the airplane.
In a real-life air drop, the package will experience lots of drag force in the ##-x## direction. So will the airplane, but it uses its engines to compensate and keep ##v_x## roughly constant. In that case, the package would land behind the airplane.
It relative speed we are dealing with.
If no external forces acted on objects then the velocity remain.
1. Ans C. The horizontal speed of the shell and tank are the same. Thus for any instant their relative position is constant that shell is always above the tank.
2. Ans A. As above their relative horizontal velocity is zero. The package lands directly above the plane since time taken and speed are the same with no external forces. After the object landed external force(friction) determine the position.
Thanks guys, I get it now, the velocity of the shell from the tank will keep moving with the same speed as the tank, and I'm guessing that's why it'll land right on top of it.
1. The shell will land on top of the tank. This is because the tank's constant motion does not affect the vertical velocity of the shell, only the horizontal velocity. Therefore, the shell will continue to move in a parabolic path and will eventually land directly above the tank's initial position.
2. The package will land directly below the plane. This is because, in the absence of air resistance, the horizontal velocity of the package will remain constant while the vertical velocity increases due to gravity. This results in a parabolic path where the package will fall directly below the plane's initial position.
FAQ: Need help with Projectile Motion Questions
1. What is projectile motion?
Projectile motion is the motion of an object through the air, under the influence of gravity. It follows a curved path and can be broken down into two components: horizontal and vertical motion.
2. What are the key factors that affect projectile motion?
The key factors that affect projectile motion are initial velocity, angle of launch, air resistance, and gravity. These factors determine the trajectory, range, and maximum height of the projectile.
3. How can I calculate the range of a projectile?
The range of a projectile can be calculated using the formula R = (v^2 * sin(2θ))/g, where R is the range, v is the initial velocity, θ is the angle of launch, and g is the acceleration due to gravity (9.8 m/s^2).
4. What is the difference between horizontal and vertical motion in projectile motion?
Horizontal motion refers to the motion of a projectile along the x-axis, while vertical motion refers to the motion along the y-axis. The horizontal motion is constant and unaffected by gravity, while the vertical motion is affected by gravity and follows a parabolic path.
5. How does air resistance affect projectile motion?
Air resistance, also known as drag, can affect the trajectory and range of a projectile by slowing it down. This is because air resistance acts in the opposite direction of the projectile's motion, reducing its velocity and altering its path.
