Nugatory
Mentor
- 15,479
- 10,619
miosim said:Per local HV theory the the predicted by QM correlation may be derived from HV that measures orientation of the corresponding detector and change photon's polarization accordingly (using function similar to Malus' law). In this case there is no need for photon pair to influences each other over the distance to achieve sufficient correlation. Instead they need just "pay attention" to the orientation of local detector only.
I don't understand what you're saying here.
Are you saying that the QM correlation can be derived from a hidden variable theory in which the result at one detector does not depend on the angle and result at the other detector? If so, you might want to try coding up a computer simulation - I expect that you'll find that it doesn't work.
