Need help with Static Equilibrium problem
The discussion focuses on a static equilibrium problem involving a 100 cm ruler placed on a table at different marks. Initially, the ruler is balanced at the 50 cm mark, but when moved to the 40 cm mark, it creates an unbalanced torque. A weightless string is attached to the ruler, with a hammer placed on it, affecting the forces in the system. Participants seek clarification on the forces acting on the ruler, specifically the weight of the hammer and its position on the ruler. Understanding these forces is crucial for analyzing the static equilibrium of the setup.
opqpop
We put a 100 cm ruler on a table at the 50cm mark. The 0cm mark is on the table and the 100cm mark is in free air. The ruler is in static equilibrium.
Now we place the ruler on the table at the 40cm mark, creating a torque on the ruler so that it is not balanced.
Next attach a weightless string with some length l at some mark on the ruler.
Then put a hammer on the string so that the head of the hammer is facing toward the ground while the bottom of the hammer is touching the ruler. (The com of the hammer is towards the table)
Here is a diagram: http://img81.imageshack.us/img81/1984/abcqc5.png
Can someone tell me what all the forces acting in this system are? Thanks
Please clarify certain things.
You want the weight Mg of the head of the hammer to act at some mark 'l' on the ruler, through the string which is attached at 'l'?
L = 60 cm?
The bottom of the hammer is touching the ruler at the 100 cm end?
What have you represented by force F?
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
