Need help with these derivatives
  • MHB
  • Thread starter rainbowbaconz
  • Tags
    Derivatives
In summary: We would like to see what you did, what you are thinking, and how you think you may be able to solve the problem. This helps us all, since we may not know what the steps are for a certain problem and would like to see it demonstrated.
rainbowbaconz
http://www.mathway.com/math_image.aspx?p=f%28x%29SMB01%28SMB02RSMB03xSMB02rSMB03+SMB02FSMB031SMB10SMB02RSMB03xSMB02rSMB03SMB02fSMB03%29SMB02ESMB033SMB02eSMB03?p=117?p=42, show that http://www.mathway.com/math_image.aspx?p=SMB02OSMB03fSMB04,xSMB02oSMB03SMB01SMB02FSMB033xSMB02ESMB033SMB02eSMB03+3xSMB02ESMB032SMB02eSMB03-3x-3SMB102xSMB02ESMB032SMB02eSMB03SMB02RSMB03xSMB02rSMB03SMB02fSMB03?p=165?p=42
http://www.mathway.com/math_image.aspx?p=f%28x%29SMB01xSMB02ESMB032SMB02eSMB03%28xSMB02ESMB032SMB02eSMB03-1%29%28xSMB02ESMB033SMB02eSMB03-1%29?p=168?p=22, show that http://www.mathway.com/math_image.aspx?p=SMB02OSMB03fSMB04,xSMB02oSMB03SMB01x%28x-1%29%287xSMB02ESMB034SMB02eSMB03+7xSMB02ESMB033SMB02eSMB03+2xSMB02ESMB032SMB02eSMB03-2x-2%29?p=273?p=22
http://www.mathway.com/math_image.aspx?p=f%28x%29SMB01SMB02RSMB03%28SMB02FSMB031-SMB02RSMB03xSMB02rSMB03SMB101+SMB02RSMB03xSMB02rSMB03SMB02fSMB03%29SMB02rSMB03?p=113?p=42, show that http://www.mathway.com/math_image.aspx?p=SMB02OSMB03fSMB04,xSMB02oSMB03SMB01SMB02FSMB033xSMB02ESMB033SMB02eSMB03+3xSMB02ESMB032SMB02eSMB03-3x-3SMB102xSMB02ESMB032SMB02eSMB03SMB02RSMB03xSMB02rSMB03SMB02fSMB03?p=165?p=42
http://www.mathway.com/math_image.aspx?p=f%28x%29SMB01SMB02FSMB032xSMB02ESMB03SMB02FSMB033SMB102SMB02fSMB03SMB02eSMB03-xSMB02ESMB03SMB02FSMB035SMB102SMB02fSMB03SMB02eSMB03+3SMB02RSMB03xSMB02rSMB03SMB10-SMB02RSMB03xSMB02rSMB03SMB02fSMB03?p=137?p=42, show that http://www.mathway.com/math_image.aspx?p=SMB02OSMB03fSMB04,xSMB02oSMB03SMB012%28x-1%29?p=107?p=22
http://www.mathway.com/math_image.aspx?p=f%28x%29SMB01SMB02FSMB03SMB02RSMB031+xSMB02rSMB03SMB10SMB02RSMB031-xSMB02rSMB03SMB02fSMB03?p=88?p=42, show that http://www.mathway.com/math_image.aspx?p=SMB02OSMB03fSMB04,xSMB02oSMB03SMB01SMB02FSMB031SMB10%281-x%29SMB02RSMB031-xSMB02ESMB032SMB02eSMB03SMB02rSMB03SMB02fSMB03?p=139?p=42
I know how to get the first derivatives for all these problems, but I'm having problem getting to these alternate derivative forms. Please help. Thanks.
Hi rainbowbaconz,
Welcome to MHB :)
We usually ask for one problem per thread, so which one shall we start with? Pick one and then show us what you did and we'll help you keep going.
Jameson
Hello and welcome, rainbowbaconz!
It is to your advantage to show what your thoughts are and/or the work you have so far so that we may specifically address where you may be going astray. This helps you in all future problems of this type, since you will be able "fix" the error in the application of the rules for differentiation.
We want to help you to understand the problems, and then to be able to apply the rules to other problems with success.
And please don't feel afraid to be wrong, no one here will think any less of you. We have all been there, trust me! The only thing to be embarrassed about is to be unsure and not ask for guidance.
Hello, rainbowbaconz!
The fourth one is elementary . . .
[tex]f(x) \:=\:\dfrac{2x^{\frac{3}{2}} - x^{\frac{5}{2}} + 3\sqrt{x}}{\text{-}\sqrt{x}}[/tex]
[tex]\text{Show that: }\:f'(x) \:=\:2(x-1)[/tex]
$\text{We have: }\:f(x) \;=\;\dfrac{2x^{^{\frac{3}{2}}} - x^{^{\frac{5}{2}}} + 3x^{^{\frac{1}{2}}}}{\text{-}x^{^{\frac{1}{2}}}} $
. . . . . . . $ f(x)\;=\;\dfrac{2x^{\frac{3}{2}}}{\text{-}x^{\frac{1}{2}}} - \dfrac{x^{\frac{5}{2}}}{\text{-}x^{\frac{1}{2}}} + \dfrac{3x^{\frac{1}{2}}}{\text{-}x^{\frac{1}{2}}} $
. . . . . . . $f(x) \;=\;\text{-}2x + x^2 - 3$Hence: ..$f'(x) \;=\;\text{-}2 + 2x \;=\;2(x-1)$
Here, refer to this.
http://www.mathhelpboards.com/misc.php?do=vsarules
These are some of the expectations when you make a thread or post.
FAQ: Need help with these derivatives
What is a derivative?
A derivative is a mathematical concept that represents the rate of change of a function with respect to its independent variable. It can also be thought of as the slope of a curve at a specific point.
Why do we need to find derivatives?
Derivatives are important in many fields of science and engineering as they help us understand how a system is changing over time. They are also used to optimize functions and solve real-world problems.
How do you find derivatives?
The process of finding derivatives involves using differentiation rules, such as the power rule, product rule, and chain rule. These rules allow us to find the derivative of any polynomial function or combination of functions.
What are some common applications of derivatives?
Derivatives are used in many areas, including physics, economics, and statistics. Some common applications include finding the velocity and acceleration of an object, maximizing profits for a business, and determining the best fit line for a set of data.
What are some tips for solving derivative problems?
Some helpful tips for solving derivative problems include understanding the basic rules and properties of derivatives, practicing with a variety of functions, and using graphs and diagrams to visualize the problem. It's also important to carefully follow the steps and double-check your work for accuracy.
