Need help with voltage regulator circuit that uses 7805
In summary, the author completed a circuit that consisted of a microcontroller unit, a LCD module, a keyboard, and a RTC module. The microcontroller unit needed +5V, so the author created a +5V regulated source by using a 7805 regulator connected to a battery. When he wired the circuit up, he noticed that the 7805 regulator's output voltage dropped from +5 V to a few millivols after connecting it to the microcontroller circuit. He also noticed that the 7805 regulator was tremendously hot. He used a heat sinker, but still got hot. This was not the first time this happened to his designs, so he went looking for alternatives. He tried a 7805 regulator that was capable
thegreengineer
54
Well let me explain. I've finished a circuit that consists in a microcontroller unit (in this case a PIC16F877A) that is connected to a LCD module, a keyboard and a RTC module (via I2C protocol). As far as I know all of them require VCC (=+5V) for operating so I needed to create a +5V regulated source. At first I used the basic configuration of a +9V battery connected to a 7805 regulator with capacitors for smoothing. The circuit was kinda this (and I say kinda because I don't remember so well the capacitors' values)
When I wired it up I noticed two things, the output voltage from the 7805 dropped from +5 V (in fact it was +5.08 V) to a few millivolts after connecting it to the microcontroller circuit. The other thing I noticed was that the 7805 regulator was tremendously hot (so hot I couldn't even touch it with my bare hands and had to wait around 1 minute to cool down). I used a heat sinker, but still got hot.
This was not the first time this happens to my designs, so I went checking for alternatives that include a 7805 regulator that are capable of sourcing more current (since as far as I know the 7805 can only supply a maximum of 1.5 A) so I wanted to know what kind of circuit design could you recommend me in order to get 5 V output with more current. I appreciate your answers and comments.
I'm assuming you are using a 7805 in the TO-220 package, the one with a plastic body, a metal mounting tab with a single mounting hole, and three leads coming out the side furthest from the mounting hole. If that is the case, it sure sounds like there is a miswire on one or more of your boards, that is to say a short circuit in the power wiring or power wired to the pins of an IC. If possible, try it with the ICs removed, and the keyboard. (They are in sockets aren't they?) Another possibility is there is an electrolytic capacitor that is wired backwards.
From the list of ICs you are using, I would expect way less than 1A load.
It sounds like you are getting an early taste of troubleshooting. That can be both the most fun and the most annoying part of a project, but you learn more from the mistakes than from the successes (darn it!).
Likes jim hardy
Sounds like just a clock. Of the elements mentioned LCD requires the highest current, but if memory serves me well it is still well below 200 mA. Before switching to something capable of delivering more current I would check what consumes so much. I suspect either a faulty element or just a short circuit somewhere.
Edit: Tom.G was faster, but he confirms my intuition - there is nothing that could draw so much current.
It would be useful to know the exact type of that '7805'. As it is now, this chip can be purchased with output current from 100mA to 1.5A and the term '7805' is also used for DCDC converters with slightly similar pinout and 5V output voltage.
You can test the 7805 regulator by connecting a 100 ohm resistor as a load. That will draw a realistic 50 mA. If the output voltage remains over +4.75V then the power supply is probably OK and the problem is with the project PCB. Has the PCB been tested with another supply?
A 7805 will go into thermal shutdown to protect itself if you short circuit the output. My guess is that you have a short circuit between common=0V=ground and +5V=Vcc on the project PCB. Start by measuring the resistance between +5V and 0V input. Reverse the meter polarity and measure again. What do you get?
If it shows a short circuit, give the PCB a close visual inspection. I would look first for a solder bridge, then for a dead bypass capacitor, maybe a tantalum capacitor or a chip installed backwards. Whatever it is will be so simple that you have overlooked it.
If it still measures a power input short circuit, then you might try lifting some bypass components as you check for a change in the resistance. Consider cutting a Vcc power supply track to isolate the fault to one part of the PCB, keep doing that until your binary search identifies the cause of the short. Do it sensibly because you will have to stitch the tracks back together.
Can you give us a link to the project circuit diagram?
Likes Tom.G and jim hardy
If you don't find any shorts or other problems with the target you may have oscillation occurring. This in turn can cause the target to malfunction to a latched-up state.
Do you have an oscilloscope handy? Does the voltage output do anything at startup? How much and what type of capacitance do you have in the target?
BoB
@MarcusAu314
Quick check internal Power limiter : How much voltage is on that 'unregulated' side ? How much power per 100 milliamps does that create inside yout 7805 ?
Quick check for oscillation: Set your DMM to AC and measure output.
LM350 is a 3 amp regulator , but like others here i think you have a short someplace.
And there are switching buck voltage regulators like this one @Baluncore recently pointed out in another thread
https://www.physicsforums.com/threads/lm317t-is-heating.928116/#post-5859837
all over Ebay
http://www.ebay.com.au/itm/Voltage-Regulator-LM2596-3A-Adjustable-DC-To-DC-Step-Down-Converter-Buck-Module/232274773224?
Related to Need help with voltage regulator circuit that uses 7805
1. What is a voltage regulator circuit?
A voltage regulator circuit is an electronic circuit that is used to maintain a constant output voltage regardless of changes in input voltage or load. It is typically used to power electronic devices that require a specific and stable voltage to function properly.
2. What is the purpose of using a 7805 voltage regulator?
The 7805 voltage regulator is a popular choice for regulating voltage due to its simplicity, low cost, and availability. It is designed to provide a stable 5V output from an input voltage range of 7-35V, making it suitable for a wide range of applications.
3. How does a 7805 voltage regulator circuit work?
The 7805 voltage regulator circuit works by using a series of internal transistors to regulate the voltage. It takes in the input voltage and adjusts it to a constant 5V output by using a feedback loop to monitor and adjust the voltage as needed. The excess voltage is dissipated as heat through a heat sink.
4. What are the components needed for a 7805 voltage regulator circuit?
The main components needed for a 7805 voltage regulator circuit are the 7805 regulator IC, capacitors (typically 0.33μF and 0.1μF), and a heat sink. Other components such as resistors and diodes may also be needed depending on the specific circuit design.
5. How can I troubleshoot issues with my 7805 voltage regulator circuit?
If you are experiencing issues with your 7805 voltage regulator circuit, there are a few things you can check. First, make sure that the input voltage is within the recommended range of 7-35V. You should also check the polarity of the capacitors and make sure they are connected correctly. If the regulator is getting too hot, you may need to add a larger heat sink or a cooling fan. If you are still having issues, consult a schematic or seek assistance from an experienced electronics technician.
