Need help working out flow rate of gas from a compressor down a pipe please.
In summary, the speaker is seeking help in calculating the flow rate of gas down a pipe, using an air compressor, a pressure gauge, and a flow control valve. They have tried using Bernouilli's equation and the volumetric flow rate equation, but have gotten unrealistic values. They are expecting the gas speed to be low enough for laminar flow, but their calculations suggest turbulent flow. They are unsure if their pressure differentials are correct and are seeking guidance on how to calculate the velocity in turbulent flow. They also mention a report that uses pressure in kPa instead of Pa and are wondering if that is where they went wrong. They would appreciate any help and are hoping to have an answer by the end of Friday.
DannyB01
Hi there, after hours of frustration I've given in and come for help! I hope this isn't too long of a question, I really would appreciate any help I can get. :)
I'm trying to work out the flow rate of gas down a pipe. My setup is simply an air compressor with a pipe coming out of it, with a pressure gauge and flow control valve about 20cm from the end (for all intents and purposes, it actually leads to a circular reed and piezoelectric sounder circuit). I thought this would be a fairly simple thing to do after a bit of reading but I'm getting values way off. I'm not an engineer and have never dealt with fluid equations in the slightest everything here is completely new to me, so apologies for any rookie errors.
All in all pipe length is about 6.2m.
The pipe's diameter is 8mm.
I'm dealing with a few different pressure differentials - 1bar, 2bar, 3bar, 4bar and 5bar.
Using air at room temperature so about 25 celsius in an environment at atmospheric pressure.
I started off using Bernouilli's equation (P + 0.5ρ*v^2 + ρgh = constant), ignored the ρgh term for being negligible and rearranged etc. eventually finding an expression for the velocity of v=(2*(P1 - P2)/ρ)^0.5. But for 5bar as the pressure differential (ie what's read on the pressure gauge and relative to the room's atmosphere), converting gives 500000Pa and putting this in the equation gives a ridiculously high value of 917m/s for the flow speed, which can't be right.
I have also tried using the volumetric flow rate equation: Q=(Pi*(P1 - P2)*R^4)/8μL. I used μ=1.98E-5 kg/(m.s) for air at this temperature, and again for 5bar I got a pretty obscene value of Q=0.41m^3/s. As a 1m length of pipe only has 5.03E-5 m^3 volume this relates to a speed of 8151m/s. Again this seems silly, and I would hope that if I could use both equations I would get at least a very similar value for the speed of the air with each!
What I was expecting was to find that the gas speed was low enough to approximate the situation to laminar flow, ie Reynolds number, Re < 2320, which I worked out would be speeds of about 4.8m/s or lower. I would also then be able to say that these speeds are low enough to not have to factor in the compression of the air leading to an increased air density.
Could you tell me what I'm missing here and show me how you'd calculate it to get a more reasonable result? I'm getting the feeling that I'll have to model it as turbulent flow and perhaps even a choked gas velocity - I'd be intimidated by that if I'm honest but will try it if that's the only way. More likely to me it seems that my values for the pressure differentials are wrong, as I've seen it said that after a short distance down the pipe the pressure will have dropped down considerably. I wouldn't quite understand this because I designed the system so that the pressure gauge is very near the end and, when the flow control valve is fully open, it reads the same pressure as the air compressor when the gas control valve is open (at the end of the pipe attached to the compressor by a snap lock I think it's called) - so if the pressure's stayed the same the first 6m down the pipe I can't see how it would've changed so dramatically in the final 20cm.
If anyone can help me with this they'll be a lifesaver. Hopefully it will be possible to work it out with what I've given you, but seeing the equations and knowing how you did it is what I'd love to know most as I'd like to actually understand where I'm going wrong. I can't stress enough how much I appreciate the help!Dan.Edit: Also, as much as I don't like to rush people, if I'm going to have to take physical measurements (which I hope I don't have to) I only really have until the end of friday for that, so it'd be nice to have an answer by then. I'm going to head to bed because 6 hours of failing fluid dynamics like this has done me in! :)
I may have found something helpful. I didn't find it anywhere else online but in this report by Donald Schroeder: http://www.psig.org/papers/2000/0112.pdf he seems to use pressure in kPa instead of Pa. Is that where I've been going wrong? Would be great if it was, and it makes a lot more sense - this would give me 25.9m/s speed for my pressure of 5bar and 13.0m/s for a pressure of 1bar. This relates to a Reynolds Number between about 6200 and 12400 though, so it would be a turbulent flow. Can someone help me with the equations I'll need to calculate a velocity with turbulent flow? I would very much appreciate it!
Lame. :(
Related to Need help working out flow rate of gas from a compressor down a pipe please.
1. How do I determine the flow rate of gas from a compressor?
To determine the flow rate of gas from a compressor, you will need to know the inlet pressure, outlet pressure, and gas properties such as density and viscosity. You can then use the ideal gas law and Bernoulli's equation to calculate the flow rate.
2. What is the ideal gas law?
The ideal gas law is a formula that describes the relationship between pressure, volume, temperature, and number of molecules of an ideal gas. It is often written as PV = nRT, where P is pressure, V is volume, n is the number of moles, R is the gas constant, and T is temperature.
3. How does Bernoulli's equation apply to determining flow rate?
Bernoulli's equation states that the sum of the pressure, kinetic energy, and potential energy per unit volume of a fluid remains constant along a streamline. This allows us to use it to calculate the flow rate of gas through a pipe based on the pressure difference between two points.
4. What factors can affect the flow rate of gas from a compressor?
The flow rate of gas from a compressor can be affected by a number of factors, including the compressor's inlet pressure and outlet pressure, the type of gas being compressed, the temperature and viscosity of the gas, and the size and shape of the pipe through which the gas is flowing.
5. Are there any limitations to determining flow rate using these methods?
While the ideal gas law and Bernoulli's equation can provide accurate estimations of flow rate, there are some limitations to using these methods. They assume ideal conditions, such as a constant gas temperature and steady flow, which may not always be the case in real-world scenarios. Additionally, factors such as friction and turbulence can also affect the accuracy of the calculations.
  • Mechanical Engineering
14K
