Need ideas on how to induce spikes on 600VDC signal
In summary: IEEEIn summary, the speaker is looking for ideas on how to inject voltage spikes onto a 600VDC signal in order to replicate a problem seen on rail equipment. They have considered using a simple RC circuit, but it would not accurately modulate and ramp up the spike amplitude. They are also concerned about feedback to the power supply and potential damage. They are open to suggestions and have already considered using a CE shock gun or stun gun, but are looking for other options. They mention the current and rise/fall times of the spikes and that the main voltage source for the experiment is a shop disconnect box. They are also familiar with EN 61000-4-x series of immunity tests, but mention that the equipment is expensive and they
IEEE
Hi,
I have an issue I hope you guys will help me solve.
I need to re-create a problem seen on Rail equipment where high voltage spikes are affecting equipment (resistive load) normally running on 600VDC.
I thought about using a simple RC circuit to produce the spikes over the 600VDC nominal voltage but it would not work because:
- Spikes need to be of a certain length (100 - 300 us duration) and a certain amplitude (1.5 up to 5 kv ) a simple RC circuit could not modulate and ramp up the spike amplitude accurately.
- Spikes will probably feed back to the power supply and damage it.
I am looking for ideas on how to inject voltage spikes on a 600VDC signal. Thoughts and ideas are more than welcome.
Thank you
IEEE
IEEE said:
Hi,
Thank you
IEEE
Welcome to the PF.
Are you familiar with the EN 61000-4-x series of immunity tests? They are done on electrical/electronic equipment in order to get a CE Mark, to be able to sell those products in the European Union (and other places).
The EN 61000-4-5 Surge test, or the EN 61000-4-4 Electrical Fast Transient tests may be what you are looking for... The equipment to run these tests is fairly expensive, but test time at local test labs is not too bad.
Thank you for the quick reply berkeman.
I am somewhat familiar with the fast transients tests but I doubt that the same equipment could be used in this case.
For my experiment, I need to be able to generate the spikes "on top" of the 600VDC nominal voltage. The fast transients created by the surge equipment used in a test lab would in my opinion either be absorbed by the power supply filters or eventually damage the power supply.
I made spikes tests on my equipment using what is commonly called a Hi-Pot tester but the results were not conclusive enough. That is why I am trying to replicate the same scenario seen by the equipment when used on a rail car.
Thanks again,
IEEE
The CE shock gun is a good idea, You can also try the stun gun for cheap. You don't need to even tough the rail, just let it jump.
Arc is RF, your rail might be very low impedance at low frequency, it is quite high impedance at RF. That's how they transmit data through wall plug AC lines for control in the house. My first guess is they are much higher than 50Ω in RF world. Get a stun gun and try it. Either it work or not, cheap to try than to talk! I think you can get it in a lot of places for cheap.
Don't the power station have arc protection? If a stun gun can bring down the whole power station, that's sad!
yungman,
I am currently building a test setup to replicate what the rail equipment would see when powered by a sub station. I will be using an AC-DC power supply to feed the 600VDC to the test unit, not a sub-station.
I also need to be able to modulate the amplitude of the spikes which I could not do with a stun gun.
I like the idea of using a stun gun but I will have to keep that as a last resort for the moment.
Let me know if you have other ideas.
Thanks anyways.
IEEE
Thank you
IEEE
What is the impedance of your 600 V line? In other words, if you generate a 1.5k or 5k spike, how much current will that require? How much current is being drawn at 600 V when the spike occurs?
What are the rise and fall times of your voltage spike?
Do you have an adequate source to create the spike at the required voltage and current?
Current for the spikes should be fairly low. At 600VDC, current consumption is around 10-12 Amps.
Rise and fall time should be fairly quick, I would say around 10% of the spike duration. It is not the rise and fall time I am concerned about, it is really how to produce the spikes on top of the 600VDC.
The main voltage source for the experiment will be coming from a shop disconnect box either 480VAC or 575 VAC limited by 100Amps fuses. AC-DC power supply can accept either.
IEEE
Welcome to the PF.
yes +1
Well yes that's what the power supply filters are supposed to do, absorb the transients, and frequently what that surge/transient equipment is designed to test. You have proposed a contradiction: you want impose 1.5kv spikes but are afraid the spikes may damage connected equipment. So which is it?
there used to be something called IEE SWC acronym for "Surge Withstand Capability" test. It's now ANSI C37.90.1, and SWC test generators are about.
The test applies spikes of shorter duration but similar voltage to yours.
It came about 1968-ish when electronic relays began to replace electromechanical ones in substations. Its purpose was to simulate the voltage induced in sensing leads during rapid collapse of fields related to substation switching, which were eating the newfangled solid state relays.
A search on that phrase might lead you to some test generator schematics. I can remember seeing some ca 1972, those'd probably be simple enough for your guys to fabricate one out of the local junkpile...
old jm
FAQ: Need ideas on how to induce spikes on 600VDC signal
1. How can I induce spikes on a 600VDC signal?
To induce spikes on a 600VDC signal, you can use a high-voltage pulse generator or a spark gap generator. These devices can create short bursts of high voltage that can induce spikes on the signal.
2. Can I induce spikes without using specialized equipment?
Yes, you can induce spikes on a 600VDC signal without using specialized equipment. One method is to use a voltage divider circuit with a high-value resistor to create a small voltage spike. Another option is to use a high-voltage capacitor in parallel with the signal to create a spike.
3. Are there any safety precautions I should take when inducing spikes on a 600VDC signal?
Yes, it is important to take proper safety precautions when working with high voltages. Make sure to wear appropriate protective gear, such as gloves and goggles, and to work in a well-ventilated area. It is also important to properly ground all equipment and to use insulated tools.
4. How can I control the amplitude and frequency of the induced spikes?
To control the amplitude and frequency of the induced spikes, you can adjust the parameters of the high-voltage pulse generator or spark gap generator. Alternatively, you can use a function generator to create a specific waveform for the spikes.
5. Can inducing spikes on a 600VDC signal damage the equipment?
Inducing spikes on a 600VDC signal can potentially damage the equipment if not done properly. It is important to use the appropriate voltage and frequency for the equipment being used. It is also recommended to start with lower voltage and frequency settings and gradually increase them to avoid damaging the equipment.
