Need info on Ferrite shielding in metallic environment
  • Thread starter kern_paillard
  • Tags
    Shielding
In summary, Bringing the antenna of a wall reader forward may help in the communication between the tag and reader, but it does not work. A highly permeable ferrite can be used to prevent the attenuation of the RF signal.
kern_paillard
Dear all,
This is my first post in the forum.
I am working on a RFID technology used in door opening systems. The wall readers, we use are typically placed behind the door, as is the case with the metal being used on the front side of the door and in the key hole casings there is the obvious problem of intereference by the metal in communication between the RFID tag & reader.
So we thought of experimenting, by bringing the antenna of wall reader a little forward i.e. to be placed inside of the KEY HOLE CASING (made of metal) on front of the door while keeping the main electronics of the wall reader behind in hopes that bringing the antenna forward would help in the communication between tag and reader, BUT it doesn't work as the reader antenna coil is placed directly on the KEY HOLE CASING courtesy Eddy currents et al.
Acc to the RFID H-book, by introducing a highly permeable ferrite btw the antenna coil and metal surface it´s posssible to prevent the occurence of eddy current (Sec 4.1.12.3)
I would like to know about the highly permeable ferrite.
exactly what kind of ferrite should I use [dimension (MAX. PERMITTED THICKNESS: 3-4mm, 52mm x 35mm), material etc]?
If anyone has worked on this problem, can you share some details?
Retuning the system, isn't allowed.
Please suggest about the ferrite material, ways to enhance the T<--> R communication and any other ideas you have.
I hope, I was able to communicate my problem clearly.
Thanks in advance,
Kern P.
Welcome to the PF, Kern. I hadn't heard of the technique you mentioned, about using the ferrite to try to prevent eddy currents in the metal from attenuating the RF signal. I don't have the book you refer to -- can you locate a web page that talks about the technique?
Doesn't the RFID system that you purchased (and cannot return) come with mounting instructions? It should use a plastic enclosure that is mounted on the outside of the door in order to avoid the attenuation problems that you are describing.
Using ferrites as asborbers in microwave and RF systems is often done, but a bit of a black art. You have to experiment with the material, location, and size a bit. I would suggest using a sheet of ferrite-loaded rubber. These sheets come loaded with various ferrites and they come in various thicknesses. They have an adhesive on the back so you can stick it down.
Cuming Microwave has a "Problem Solver Kit" that has a varitey of materials and thicknesses:
http://www.cumingcorp.com/pdf/310-Rubber%20Sheet%20Absorbers/TB301_Problem%20Solver%20Kit.pdf
Emerson and Cuming Company also offers a free kit:
http://www.emersoncumingmp.com/sales/sample_tube.htm
As does ARC Technologies:
http://www.arc-tech.com/
You may want to get some of these and experiment to see what works best for your application.
Hope this helps.
Related to Need info on Ferrite shielding in metallic environment
1. What is Ferrite shielding?
Ferrite shielding is a type of electromagnetic shielding used to reduce the effects of external magnetic fields on electronic devices. It is made from a type of ceramic material called ferrite, which is a compound of iron oxide and other metals.
2. How does Ferrite shielding work?
Ferrite shielding works by absorbing and redirecting magnetic fields away from the protected device. The ferrite material is able to do this because its magnetic properties allow it to create a path of least resistance for the magnetic field to follow, effectively shielding the device.
3. What are the benefits of using Ferrite shielding in a metallic environment?
Ferrite shielding is particularly useful in metallic environments because metals can reflect and amplify magnetic fields, making them more difficult to shield. By using ferrite shielding, the magnetic fields can be redirected and absorbed, preventing interference and potential damage to electronic devices.
4. Are there any limitations to using Ferrite shielding?
While ferrite shielding is effective in reducing the effects of magnetic fields, it is not 100% efficient. It may not be able to completely eliminate all interference, especially in high-powered magnetic fields. Additionally, ferrite shielding is only effective against magnetic fields and does not protect against other types of electromagnetic radiation.
5. How do I choose the right type of Ferrite shielding for my application?
The type of ferrite shielding needed will depend on the strength of the magnetic fields present and the level of shielding required. Thinner sheets of ferrite are suitable for low to moderate magnetic fields, while thicker sheets are needed for strong magnetic fields. It is important to consult with a specialist to determine the best type of ferrite shielding for your specific application.
  • General Discussion
  • Aerospace Engineering
