Need info on 'Guard Pin' of ICs
  • Thread starter pgokhale
  • Tags
    Pin
In summary, the conversation discusses the use and significance of a "guard pin" on the IC from Analog Devices - AD549. The pin is connected to the case and is used to shield the circuit from external fields. It is similar to a "guard ring" and is particularly useful in sensitive high-gain amplifiers to prevent stray feedback and leakage currents. The AD549 datasheet provides more information on this topic.
pgokhale
Hi!
I came across an IC from Analog Devices - AD549, and happened to see a pin labelled as 'Guard pin'. It is being mentioned that the pin is connected to case.
I would like to understand more on the significance of this pin - its need and how to deal with it.
Also, is guard pin's need same as that of 'guard ring'?? Please advice.
Thanks in advance,
PGokhale.
As far as I know, those are used to shield the circuit (or pin, or connection, or whatever) from external fields.
Thank you mfb :) but if the op-amp is employed in low power scenario - employing only dc currents and voltages, the fields could be negligible. In this case how guard pin makes its usage prominent?
I can picture where an earthed guard pin would be useful as a separation between input pins and pins carrying the amplified output in a sensitive high-gain amplifier. You don't want stray feedback from output back to input.
The PCB trace that carries the input signal to your opamp isn't perfectly insulated, i.e. there's distributed resistance between it and adjacent traces, between it and the opamp package and so on. Nearby voltage gradients can thus cause current to flow in your signal line which might swamp out your input signal.
You can divert this leakage current away by surrounding your signal line with a low impedance trace that's biased at the same voltage as your signal line. The guard pin allows you to make the opamp case a part of this guard conductor.
The AD549 datasheet includes information about this under the heading "Circuit Board Notes".
@ NascentOxygen, milesyoung : thank you :) sounds good :)
Related to Need info on 'Guard Pin' of ICs
1. What is the purpose of a guard pin on an IC?
The guard pin on an IC (integrated circuit) is used to minimize capacitive coupling between the input and output pins of the IC. It helps to prevent external signals from interfering with the internal circuitry of the IC, which can lead to errors or malfunctions.
2. How does a guard pin work?
A guard pin works by creating a connection between the input and output pins of the IC. This connection is usually a low-impedance path that allows any external signals to be shunted to ground, reducing their impact on the internal circuitry. This helps to maintain the accuracy and reliability of the IC.
3. Can a guard pin be used on any type of IC?
Yes, a guard pin can be used on a variety of ICs, including operational amplifiers, comparators, and analog-to-digital converters. However, the specific placement and function of the guard pin may vary depending on the type of IC and its intended use.
4. How is a guard pin connected in a circuit?
The guard pin is typically connected to the ground or a low-impedance reference voltage in the circuit. It can also be connected to a guard ring, which is a conductive ring surrounding the IC to provide additional shielding from external signals.
5. What are the benefits of using a guard pin on an IC?
The use of a guard pin can improve the accuracy, stability, and noise immunity of an IC. It can also help to reduce the effects of parasitic capacitance and improve the overall performance of the IC in a variety of applications.
