awholenumber
- 200
- 10
I wish i had one book or pdf to learn about different types of fractions .
Please help
Please help
The way I remember it is that in an improper fraction, the numerator is greater than or equal to the denominator, so 3/2 would be an improper fraction. A number like 1 1/2 is called a mixed number. I agree that mixed numbers really have no place in mathematics.fresh_42 said:As a consequence, the classification "improper" is nonsense.
About all you need to know about fractions is covered in @fresh_42's post #4: i.e., how to add, subtract, multiply, and divide fractions. Don't overthink this.rosekidcute said:Other than that book , i have not come across any quality materials on fractions
Yes, that's also what is said in the OP's link. But what is it good for? I consider it ballast. I cannot imagine a case where it is necessary to name quotients ##\frac{4}{5}## and ##\frac{5}{4}## differently. It seems only to be necessary if one wants to write the improper ones as "mixed numbers". But in the end it's an opinion. Dropping a "+" sign in a framework which usually drops "##\cdot ##" is questionable at least, proper and improper ... whomever it fits. It wouldn't be my first choice when learning about fractions.Mark44 said:The way I remember it is that in an improper fraction, the numerator is greater than or equal to the denominator, so 3/2 would be an improper fraction.
I agree completely.fresh_42 said:Yes, that's also what is said in the OP's link. But what is it good for? I consider it ballast.
The only place where this concept comes into play again is in Partial Fraction Decomposition, which could be used in this integral: ##\int \frac{x^2}{x^2 - 1}##. Here the integrand is an improper rational function. Writing the integrand as ##\frac A {x^2 - 1} + \frac B {x^2 - 1}## won't work, but using polynomial division or a clever trick, one could write the integral as ##\int [1 + \frac 1 {x^2 - 1}]dx##, and then break this into two integrals and use partial fractions or a trig substitution on the last part.fresh_42 said:I cannot imagine a case where it is necessary to name quotients ##\frac{4}{5}## and ##\frac{5}{4}## differently. It seems only to be necessary if one wants to write the improper ones as "mixed numbers". But in the end it's an opinion. Dropping a "+" sign in a framework which usually drops "##\cdot ##" is questionable at least, proper and improper ... whomever it fits. It wouldn't be my first choice when learning about fractions.
If there any such books, they must be very thin; there's not very much to say about fractions. Any book on arithmetic should have a section on fractions.rosekidcute said:I wish i had one book or pdf to learn about different types of fractions .
Fractions are a way of expressing a part of a whole. They are written as a numerical value over another numerical value, separated by a line. The top number is called the numerator and the bottom number is called the denominator.
There are several types of fractions, including proper fractions, improper fractions, mixed numbers, and equivalent fractions. Proper fractions have a numerator that is smaller than the denominator, while improper fractions have a numerator that is equal to or greater than the denominator. Mixed numbers have a whole number and a fraction combined, and equivalent fractions represent the same value but are written differently.
To add or subtract fractions, you must first make sure they have the same denominator. If they do not, you will need to find a common denominator. Once the fractions have the same denominator, you can add or subtract the numerators and keep the denominator the same. Simplify the resulting fraction if necessary.
To multiply fractions, simply multiply the numerators together and the denominators together. To divide fractions, flip the second fraction (also known as the reciprocal) and then follow the same steps as multiplication. Remember to simplify the resulting fraction if possible.
There are many resources available for learning and practicing fractions. You can find online tutorials, worksheets, and games to help you understand and improve your skills. You can also work with a tutor or join a study group to further enhance your understanding of fractions.
