Need maximum weight on an extension machine
To achieve maximum weight and resistance on a centered axis extension machine using a pulley system, it’s essential to consider the design constraints and desired resistance levels. Reducing the number of pulleys can increase resistance, but this may not be feasible depending on the machine's design. Lowering the attachment point of the cord towards the feet on the leg support can also enhance resistance. Visual aids, such as diagrams of the current mechanism, can help clarify the setup and potential modifications. Providing more specific details about the machine's design will facilitate better advice on optimizing resistance.
idontknoww
TL;DR Summary: Need ideas on how to get maximum weight/resistance out of a pulley system in a centered axis extension machine
Hi so I am studying mechanical engineering and am currently working on a factory that makes gym machines, and I wanted to know if anyone could explain to me how I could get maximum resistance/weight with a pulley system. The only thing that comes to mind is using less pulleys, which I don’t think I can, and the second thing I thought of is putting the end of the cord lower towards the feet on the leg support thing (sorry don’t know the name of that). Helps a loooot if you could explain visually
Welcome to PF.
You can attach a picture of the existing machine mechanism to your next post.
There is an "Attach files" button at the bottom left of the reply window.
Fix the rope to the floor.
Seriously tough, you need to be more specific about the design constraints and desired resistance.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
