High School Need some clarification to get dimensions for a volume
  • Thread starter Thread starter AjaxOfTheRockies
    Dimensions Volume
The discussion revolves around converting a volume of 0.04 cubic centimeters into usable dimensions for a shop project. A cube with this volume was initially calculated to have sides of approximately 3mm, but this was corrected to 3mm yielding a volume of only 0.027 cc. The main query then shifted to determining the dimensions of a cylinder with the same volume, where the shape can vary significantly depending on the desired proportions. It was suggested that for a cylinder with equal length and diameter, the volume can be calculated using the formula for the volume of a cylinder, which relates the length and diameter. Practical advice included measuring the internal diameter of an available cylinder to calculate the necessary height for the desired volume.
AjaxOfTheRockies
I have a volume of 0.04 cubic centimeters. I need to convert into something I can work with in my shop. Tolerance is not important.
To get dimensions of a cube with this volume, I calculated the cube-root which came out to 0.341. So, my cube would be (rounded) 3mm on a side, correct?
Next question, is what dimensions would a cylinder of 0.04 cc be? That one left me completely stumped. I see lots of instruction online on how to take a dimensions of a cylinder and calculate the volume, but nothing on the reverse.
Thanks!!
—A
[edited to correct my starting number]
Mathematics news on Phys.org
A cube of side length ##3 \ mm## would have a volume of ##0.3^3 \ cm^3##, which is ##0.027 \ cm^3##.
It depends on the shape of your cylinder: long and thin or short and fat. There are lots of different cylinders with that volume, all with a different shape.
Thanks for the info. On the cylinder, I was thinking of one near equal width/length
If the length and diameter of the cylinder are both ##l##, then the radius is ##\dfrac l 2##. The cross-sectional area is ##\pi (\dfrac l 2)^2## and the volume is ##\pi \dfrac{l^3}{4}##.
Excellent! Thank you!!
... On the cylinder, I was thinking of one near equal width/length
Just a relation that you may find interesting:
https://www.mathsisfun.com/geometry/cone-sphere-cylinder.html
In practical terms, I would carefully measure the internal diameter of a suitable cylinder that you may have available, and then calculate what height achieves the desired volume you need to work with in your shop.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
