Need the Permissible Stress (Shear & Bending) values of various materials
In summary, the permissible stress for shear in steel is typically around 0.4 times the yield strength of the material, but can vary depending on the grade and composition of the steel. For bending in aluminum, the allowable stress depends on the alloy and temper, usually ranging from 30-60% of the ultimate strength. Permissible stress is the maximum stress a material can withstand without permanent deformation, while ultimate stress is the maximum stress before failure. Temperature and loading rate can affect the permissible stress, with higher temperatures and loading rates resulting in lower permissible stress. Different materials have different permissible stress values due to their unique mechanical and physical properties.
ANSAN
TL;DR Summary
Need Permissible stress (Shear & Bending) values of various materials that is used for shaft design.
Hi all, i need Permissible stress (Shear & Bending) values of various materials that is used for shaft design, as like below.
Is there any software or excel sheet.
kindly let know.
Thankyou Lnewqban, I will check it.
Thanks for your guidance...!
Likes berkeman
Related to Need the Permissible Stress (Shear & Bending) values of various materials
What is the permissible stress for shear in steel?
The permissible stress for shear in steel varies depending on the specific type of steel and its properties. Generally, the range is between 40,000 psi to 80,000 psi.
What are the permissible stress values for bending in aluminum?
The permissible stress values for bending in aluminum also vary depending on the specific type and grade of aluminum. They can range from 10,000 psi to 30,000 psi.
How do I determine the permissible stress for a specific material?
The permissible stress for a specific material can be determined by consulting engineering handbooks or material data sheets. These resources provide information on the properties and allowable stresses for various materials.
Why are there different permissible stress values for different materials?
Different materials have varying strengths and properties, which determine their ability to withstand stress. Therefore, the permissible stress values are different for each material to ensure safety and prevent failure.
Are there any safety factors to consider when using permissible stress values?
Yes, there are safety factors that should be considered when using permissible stress values. These factors account for uncertainties in material properties, design assumptions, and potential variations in loading conditions.
  • Mechanical Engineering
