Rageuke
- 7
- 1
- Homework Statement
- Give an expression for the number of these red giants that can be observed with a given apparent
brightness ๐ can be observed within a solid angle ฮฉ.
Express this as ฮN/ฮ๐ as a function of ๐. Assume that this type of red giant represents a certain fraction ๐ of the total star population. Further assume also that for this calculation there is no
extinction of the interstellar medium. (Hint: use the given Taylor series that is valid when ๐ฅ โช 1).
- Relevant Equations
- Taylorseries: log(1 + ๐ฅ) = 1/ln(10)*( ๐ฅ โ ๐ฅ^2/2 + ๐ฅ^3/3 โ ๐ฅ^4/4 + โฏ )
Assume that the density distribution of stars in the Galaxy can be represented by the following exponential function:
๐(๐) = ๐0*๐^โ((๐โ๐ 0)-(๐ ๐))
Herein:
๐ represents the distance from the center of the Galaxy,
๐ 0 the distance from the Sun to the center of the Galaxy,
๐ ๐ the radius of the disk of the Galaxy,
๐0 is the density of stars in the vicinity of the Sun.
All distances in the above model are given in ๐๐๐.
An astronomer observes a certain type of red giants in the center of our Galaxy that can be used as standard candles with a constant absolute brightness of ๐ = -0.2.
My hypothesis:
The number of red giants is equal to the number of stars times the given fraction f.
The number of stars in a solid angle omega, is given by the density distribution of stars in the Galaxy times the volume of the observed solid angle:
#RG = f*n(r)*V
where V = (d^3*omega)/3.
I assume the maxium distance at which a telescope can see red giants with a given apparent magnitude m is equal to distance d mentionned in the equation above, which can also be calculated with the following formula (relating the apparent magnitude to the absolute magnitude):
M = m + 5 - 5*log(d)
where the base of log is 10
which gives
d = 10^((M-m-5)/(-5))
If you substitute everything, you become an expression with the only variable being the apparent magnitude...
My questions are:
The expression I computed is not expressed as ฮN/ฮ๐, what could I change to my formul to achieve this?
Shouldn't I use an integral to integrate n(r) to the volume V, to determine the number of stars?
What does the expression ฮN/ฮ๐ stand for? The number of red giants with a given apparent magnitude m?
It is said I must use the given Taylorseries, I don't know where or when...
Thx in advance for your help! :D
#RG = f*n(r)*V
which gives
My questions are:
