Need to interrupt a low voltage lighting loop circuit
In summary, this low voltage lighting loop circuit should work fine as long as the rail is a continuous circle. The top or bottom half of the circuit is being energized at the same time, but that shouldn't matter since each side of the rail runs in an uninterrupted loop. The system would only draw about 300 watts, which is not much compared to the 20 foot circle it would be in. Thanks for the help!
lightingguy
Need to interrupt a low voltage lighting "loop" circuit
I configure a lot of low voltage lighting for a living. Although it's not a deal-breaker for the project I'm working on, I'm having a disagreement with a colleague as to whether the following configuration should work:
Shapeable, low-voltage track lighting (monorail we call it) is made of two pieces of exposed conductive material attached to either side of an insulating material between them. The bulb-holding fixtures then attach to the rail with connectors that touch conductive material on either side of the insulated material and there you go.
Typically these systems are installed so that the rail is a straight line, or a "S" or "C" curve or something...but they can also be formed into complete squares or circles.
Question is, if you form the rail into a square or a circle, do you need to interrupt the rail loop with an isolating connector (these are available) or will it matter to let them connect back to themselves?
My position is that, even if the rail is in a continuous circle, the top or bottom half is being energized all at once opposite the other side and the fact that each conductive side of the rail runs in an uninterrupted loop shouldn't matter. My colleague thinks this will interfere with the circuit somehow and add load to the transformer.
In my mind, this isn't any different to taking the low voltage leads from a transformer, running these wires out 20 feet, then attaching each to itself near the transformer again...would that really stress a transformer?
If it matters, these are AC transformers, 12 volt systems typically no more than 300 watt total draw. System would be about a 20 foot circle.
Thanks for any insight...
Welcome to the PF.
Your position is correct. As long as it is the same conductor that joins back up with itself in the closed figure, everything is fine.
What you are describing is exactly the same as "ring main" wiring for mains power sockets (at least that's what it is called in the UK). For higher currents it has the advantage that there are two wires in parallel supplying the current to the load (i.e. the two halves of the "ring") so you can safely use thinner gauge wiring, though that probably isn't relevant for your application.
Your colleague might be thinking about a single "shorted turn" of wire around the transformer core (which is a very bad idea!) but that's a different situation from what you have.
Thanks to you both guys for taking the time to answer my question.
It's always good to hear you're not going crazy.
Related to Need to interrupt a low voltage lighting loop circuit
1. What is a low voltage lighting loop circuit?
A low voltage lighting loop circuit is a type of electrical circuit that is used to power low voltage lighting fixtures. It typically consists of a transformer, wiring, and multiple lighting fixtures connected in a loop.
2. Why would I need to interrupt a low voltage lighting loop circuit?
There are a few reasons why you may need to interrupt a low voltage lighting loop circuit. One common reason is to make repairs or modifications to the circuit, such as replacing a damaged fixture or adding a new one. Another reason may be to turn off the circuit for safety purposes, such as during maintenance or in case of an emergency.
3. How do I interrupt a low voltage lighting loop circuit?
To interrupt a low voltage lighting loop circuit, you will first need to locate the transformer, which is usually located near the power source. Then, you can turn off the circuit by either unplugging the transformer or flipping the designated circuit breaker. Once the circuit is off, you can safely make any necessary repairs or modifications.
4. Can I interrupt a low voltage lighting loop circuit while the power is on?
No, it is not safe to interrupt a low voltage lighting loop circuit while the power is on. This can cause an electrical shock or damage to the circuit. It is important to always turn off the power source before interrupting a low voltage lighting loop circuit.
5. Are there any safety precautions I should take when interrupting a low voltage lighting loop circuit?
Yes, it is important to take some safety precautions when interrupting a low voltage lighting loop circuit. Always make sure the power is off before working on the circuit and use caution when handling any wiring or fixtures. It may also be helpful to wear protective gear, such as gloves and safety glasses, to prevent any accidents. If you are unsure about how to safely interrupt the circuit, it is best to consult a professional electrician.
  • Electrical Engineering
12K
11K
