Neeed help with a laplace transform
In summary, the conversation is about the Laplace transform and using it to solve a problem involving a piecewise defined function. The function is defined as \theta(t) = 0 for t<0 and \theta(t) = 1 for t \geq 0. The knowledge of \theta(t) being equal to 1 for t>0 should be helpful in solving the problem. The conversation also includes a discussion about using LateX to input mathematical expressions.
Lorens
29
What is the laplace transform of
http://img150.imageshack.us/img150/8145/laplacetransform6wk.jpg
According to the section entitled "Homework Help" in the Physics Forums Global Guidelines which you agreed to:
NOTE: You MUST show that you have attempted to answer your question in order to receive help.
So what are you got?
It isn't so much to test, just to watch a tabel of formula, i know the transform for cos(x), but i can't find any rule which would let me multiplicat it with O(x).
I mean for problems like this you just think, and try to figure out how to do it.
I would say my problem is O(x).
Anyway i got to go to bed now 00:08.. lol...
Do you know what [itex]\theta(t)[/itex] is?
for [itex]\theta(t)[/itex] t<0 gives t=0 and t>0 gives t=1 and the transform is 1/s, but that knowledge don't help me much :( ...
You are right about [itex]\theta(t)[/itex], but that knowledge should help you a great deal.
You have a function that is defined piecewise:
[tex]\theta(t) = \left\{ \begin{array}{cc}0 & t<0\\1 & t \geq 0\end{array}[/tex]
Now, if you multiply [itex]\theta(t)[/itex] by [itex]\cos(t)[/itex], then you just have to multiply both pieces by [itex]\cos(t)[/itex].
So...
[tex]\cos(t)\theta(t) = \left\{ \begin{array}{cc}0 & t<0\\\cos(t) & t \geq 0\end{array}[/tex]
Can you take it from there?
You missed that [itex]\theta(o)[/itex]=1/2 my textbook say so, but it don't matter.
Can I ignore [itex]\theta(t)[/itex] seen the laplace transform isn't defined for the second quadrant for the x-axis.
Also i must ask how do you get access to all the special signs?
Thx for your time Lorenz
It's not a matter of being undefined, but you got the right idea. It's more precise to state that the laplace transform of f doesn't care what values f takes on for x<0.
What special signs?
Like [itex]\theta(t)[/itex] i just copyed him there :smile:
FAQ: Neeed help with a laplace transform
1. What is a Laplace transform?
A Laplace transform is a mathematical tool used to convert a function in the time domain to a function in the frequency domain. It is commonly used in engineering and physics to solve differential equations.
2. How do I perform a Laplace transform?
To perform a Laplace transform, you need to apply the Laplace transform formula to the function you are given. This formula involves integrating the function with respect to the variable "s" and multiplying it by the exponential function of "-st". The result of the integration is the transformed function in the frequency domain.
3. What are the benefits of using Laplace transforms?
Laplace transforms have several benefits, including simplifying differential equations and making it easier to solve them. They also allow for the analysis of systems in the frequency domain, which can provide insights into the behavior of the system.
4. Can Laplace transforms be applied to any function?
No, Laplace transforms can only be applied to functions that are "Laplace transformable". This means that the function must satisfy certain conditions, such as being continuous and having a finite number of discontinuities.
5. How can I use Laplace transforms in real-world applications?
Laplace transforms have a wide range of applications in fields such as engineering, physics, and mathematics. They are commonly used to analyze and solve problems in control systems, circuit analysis, and signal processing. They can also be used to model and understand physical systems such as electrical circuits, mechanical systems, and fluid dynamics.
