Negating Definition of Function: A=>B
  • MHB
  • Thread starter solakis1
  • Tags
    Definition
In summary, the definition of a function from the set A to the set B is a subset of AxB where for every a belonging to A there exists a unique b belonging to B,such that (a,b) belongs to f.
solakis1
422
We know that we define a function from the set A to the set B ,denoted by f: A=>B
iff:
1) f is a subset of AxB
2) For every a belonging to A ,there exists a unique b belonging to B,such that (a,b) belongs to f
In trying now to negate the above definition i got stuck ,particularly in negating statement (2).
Because i had to first correctly formalize the statement and then negate it by appling the appropriate laws of logic.
I would work from the outside in. To go to symbols here,
$$2) \; (\forall a \in A)(\exists \text{ unique }b \in B)|(a,b) \in f.$$
The tricky part, it seems to me, is the uniqueness. How can you get that into symbols?
Take a simpler case: try translating the statement "There exists a unique $x$ satisfying property $P$" into symbols. How can you get at the uniqueness?
Thanks for your help,should not the formula that you suggest be first of all a well formed formula?
Absolutely, it should. I was not worrying about syntax overmuch. How would you get it to be a wff?
We have to follow the rules
Well, yes. That's not exactly what I was driving at. Why don't you take the formula I gave above, and turn it into a wff? What would be that specific result?
Adrian, I caution you with a tale of "Brer Rabbit:"
And the rule is:
1)If G is an n place predicate symbol and \(\displaystyle t_{1},t_{2}...t_{n}\) are terms (not necessarily distinct),then \(\displaystyle G(t_{1},t_{2}...t_{n})\) is a formula (an atomicformula)
2) If P and Q are formulas,then (P=>Q),(PvQ),(P^Q) ARE formulas.
3)if P is a formula then ~P is a formula.
4)If P is a formula and u is a variable ,then \(\displaystyle \forall u P\) is a formula
5) If P is a formula and u is a variable ,then \(\displaystyle \exists u P\) is a formula
6) Only strings (= a finite sequence of symbols) are formulas,and a string is a formula only if its being so follows from (1).(2),(3),(4).or (5)
According to (4) and (5) in the above definition strings of the form \(\displaystyle \forall a\in A\), \(\displaystyle \exists b\in B\) are not correct,but strings of the form \(\displaystyle \forall a(a\in A)\) ,\(\displaystyle \exists b(b\in B)\) are
Do you agree?
Thread closed for moderation.
FAQ: Negating Definition of Function: A=>B
What is the definition of negating a function?
Negating a function is the process of finding the opposite or inverse of a given function. This means finding another function that, when applied to the output of the original function, results in the input value.
What does A=>B mean in negating a function?
A=>B is a notation used in mathematics to represent a function, where A is the input and B is the output. In negating a function, A=>B means that the original function takes an input A and produces an output B.
How do you negate a function?
To negate a function, you must first find its inverse, which is another function that, when applied to the output of the original function, results in the input value. Once the inverse is found, you can use it to negate the original function by switching the input and output values. This means that the new function will take an input B and produce an output A.
What is the purpose of negating a function?
Negating a function can be useful in solving equations, finding the roots of a function, and understanding the relationship between different functions. It can also help in simplifying complex functions and identifying patterns in data.
Can any function be negated?
Not all functions can be negated. Functions that are not one-to-one, meaning that they have multiple inputs that produce the same output, cannot be negated. In addition, functions that do not have an inverse, such as a constant function, cannot be negated.
