Negating the uniqueness quantifier
  • I
  • Thread starter Mr Davis 97
  • Tags
    Uniqueness
In summary: Therefore, the negation is logically equivalent to the statement that either 0 or more than 1 value of x satisfies P(x).In summary, the negation of ##\exists ! x P(x)## is ##\forall x (\neg P(x) \lor \exists y (P(y) \wedge y \ne x))## and it can be interpreted as either none or more than one value of x satisfies P(x). It is also logically equivalent to the statement that either 0 or more than 1 value of x satisfies P(x).
Mr Davis 97
1,462
44
I am trying to negate ##\exists ! x P(x)##, which expanded means ##\exists x (P(x) \wedge \forall y (P(y) \rightarrow y=x))##. The negation of this is ##\forall x (\neg P(x) \lor \exists y (P(y) \wedge y \ne x))##. How can this be interpreted in natural language? Is it logically equivalent to the statement that either 0 or more than 1 value of x satisfies P(x)?
Yes, because there exists exactly one are two statements: existence and uniqueness, so both can be violated in the negation. This means either none exists at all or if, then more than one.
There is exactly one odd prime. is wrong, so the contrary is true: there are either more than one odd primes (true) or all primes are even (wrong). But true or wrong is true.
There is exactly one even prime greater than ##2##. is wrong, so the contrary is true: there are either more than one even prime greater than ##2## (wrong) or all primes greater than ##2## are odd (true). Again wrong or true is true.
The case true and true cannot occur, since either there are many or none at all, which cannot both be true. So the negation of ##\exists !## can be expressed by an exclusive or, sometimes noted as ##\dot{\vee}##.
You want to negate "There exists a unique x such that the statement P(x)" holds. One expects that the negation is "There is no unique x such that P(x) holds"
The last one is a true statement if either the existence fails, or the uniqueness.
The former means that there just isn't an x such that P(x) holds, the latter means that two different ones can be found such that the statement holds and this is precisely what the logic describes (because there is no x such that P(x) holds is equivalent with saying that for all x P(x) does not hold)
Related to Negating the uniqueness quantifier
1. What is the uniqueness quantifier?
The uniqueness quantifier is a logical symbol (∃!) used in mathematics and logic to denote the existence of one and only one object that satisfies a given condition. It is used to assert that there is exactly one unique object that meets a specific criteria.
2. How is the uniqueness quantifier negated?
The uniqueness quantifier can be negated by using the symbol ¬∃!, which means "it is not the case that there exists exactly one unique object". This would be read as "there does not exist one and only one object" that satisfies the given condition.
3. What does it mean to negate the uniqueness quantifier?
Negating the uniqueness quantifier changes the meaning of a statement from asserting the existence of one unique object to denying the existence of one unique object. This means that instead of saying "there exists exactly one unique object", the statement would now be read as "there does not exist one and only one object".
4. What is an example of a statement using the negation of the uniqueness quantifier?
An example of a statement using the negation of the uniqueness quantifier is "¬∃!x (x > 0)", which would be read as "there does not exist exactly one unique positive number". This means that there is either no positive numbers or there are multiple positive numbers that satisfy the given condition.
5. How is the negation of the uniqueness quantifier used in mathematics?
The negation of the uniqueness quantifier is used in mathematics to make statements about the absence of a unique solution or object. This can be useful in proving mathematical theorems and solving equations where the uniqueness of a solution is not guaranteed. It is also commonly used in set theory and predicate logic.
