Negative amount of particles in statistical mechanics
In summary, the conversation discusses the possibility of having a negative number of particles in a system subjected to a grand canonical ensemble. This can happen because the number of particles in statistical physics is not necessarily an integer and can even be negative, while the actual number of particles in a physical system is always an integer greater than zero. It is also mentioned that this scenario could potentially be explained by the existence of dark matter. Additionally, the concept of considering an ensemble average is brought up, which allows for the consideration of fractional numbers of particles. The use of ##\Omega=U-\mu N## in this context is also mentioned.
Catria
152
Suppose that you have [itex]N = \left(\frac{\partial U}{\partial \mu}\right)_{S,V} < 0[/itex], supposedly the number of particles, even though the actual number of particles is greater than zero. This means that you can have, in a system subjected to a grand canonical ensemble, less than 0 particle for statistical physics purposes (or less catastrophically a non-integer number of particles), yet the actual number of particles is an integer greater than 0. Or would it otherwise mean that negative numbers of particles are physically possible (albeit as dark matter since standard model particles have all been detected in positive numbers)?
I fail to understand how can the stat-mech number of particles, which can be non-integer, or negative even, represent something different from an actual physical quantity. I knew [itex]\mu[/itex] represented the internal energy per particle, however.
Catria said:
Suppose that you have ##N = \left(\frac{\partial U}{\partial \mu}\right)_{S,V} < 0##, supposedly the number of particles, even though the actual number of particles is greater than zero.
Do you have an actual case in mind where this happens? Or a reference describing one?
Don't you habe to consider ##\Omega=U-\mu N## instead of U? Remember that you are considering an ensemble average, so fractional numbers aren't that peculiar. Whether negative values for N Marke sense vor not, depends on the system, e.g. considering positrons AS negative amount oft electrons.
Related to Negative amount of particles in statistical mechanics
1. What does it mean to have a negative amount of particles in statistical mechanics?
In statistical mechanics, particles are typically considered to be discrete and indivisible units. A negative amount of particles would violate this assumption and is therefore not physically meaningful. It is often used in theoretical calculations for convenience, but does not have a physical interpretation.
2. Can negative particles exist in reality?
No, negative particles do not exist in reality. As mentioned before, they are used in theoretical calculations but do not have a physical interpretation. In reality, particles have a positive and discrete quantity.
3. How are negative particles accounted for in statistical mechanics calculations?
In statistical mechanics, negative particles are often used to balance out the total charge or energy of a system. They are typically treated as mathematical constructs and do not have a physical significance.
4. Can negative particles affect the behavior of a system?
No, negative particles do not have a physical presence and therefore cannot directly affect the behavior of a system. However, in theoretical calculations, they may be used to account for certain properties of a system.
5. Are there any real-life applications of negative particles in statistical mechanics?
No, negative particles are not used in real-life applications. They are purely theoretical constructs and do not have a physical interpretation. In practical applications, particles are always considered to have a positive quantity.
  • Quantum Interpretations and Foundations
10K
  • Quantum Physics
  • STEM Academic Advising
