Negative in a Electric Potential Energy/Kinetic Energy Question
In summary, the conversation discusses the calculation of the maximum velocity of an electron that is moved away from a fixed charge. The electric potential energy and kinetic energy equations are used to equate the change in energy of the electron, with the negative sign indicating a decrease in kinetic energy. The issue with the speed of light is not relevant unless special relativity is mentioned.
mistermill
My questions reads:
An electron is pulled away from a fixed charge of 1.3μC. The electron is moved from the positive charge to 4.0 cm away from the charge. If the electron is released from the 4.0 c mark, what is the max velocity of the electron?
Ep = k q1q2/r - electric potential energy
k = 9x10^9
q1 = -1.6 x 10^-19 C
q2 = 1.3 x 10^-6 C
r = 4.0 cm = 0.04 m
Ek = 1/2 mv² - kinetic energy
m = 9.11 x 10^-31 kg
v = ?
Ep = Ek because all the electric potential energy is converted to kinetic energy when velocity is at its maximum.
kq1q2/r = 1/2 mv²
Since q1 is the charge of the electron, it is negative, so the left hand side of the equation is negative. That makes taking the square root impossible. But if I ignore the negative, I get the right answer in the text.
Does that mean the sign of the Ep is not important, or that the magnitude (the absolute value) is all that matters?
Or is it because the first equation should be the net energy =0 and the Ep gets moved algebraically and the negative disappears?
The answer I get when I ignore the negative, and the answer given in the text is 3.2 x 10^8 m/s
This is faster than the speed of light, which also confuses me a bit. Maybe just not a well written question?
This is a case where the distinction between the electric potential function and electric potential energy is important. Many different functions can be used as the electric potential function for the same system, since it is merely a type of antiderivative of the electric field. It is because of this status that it can be used to evaluate the work integral that tells us the total change in energy of the electron when moved between two points in the electric field (the fundamental theorem of calculus). This change in electric potential energy is the quantity you are equating to change in kinetic energy of the electron.
The change in potential energy is positive if we pull the electron away from the proton, and therefore negative if the electron moves in the opposite direction. When the electron is released, since there are no other forces acting on it, the Work-Energy theorem allows us to equate the change in electric potential energy with its change in kinetic energy. But remember it is change that is being equated, not particular values of potential energy or kinetic energy. Therefore, even if you got a negative change in potential energy, this would correspond to a decrease in kinetic energy, not an equation between a particular kinetic energy and a negative value. In symbols, then, your negative change in electric potential is equated to [tex]\frac{1}{2}mv_i^2 - \frac{1}{2}mv_f^2 = 0 - \frac{1}{2}mv_f^2[/tex] since the electron's initial velocity was 0. This should alleviate your worries about signage.
As for the problem with the speed of light, it is indeed not a prudent type of question, unless the author is going to use it as an example later when they mention special relativity.
FAQ: Negative in a Electric Potential Energy/Kinetic Energy Question
1. What is electric potential energy?
Electric potential energy is the energy that a charged object has due to its position in an electric field. It is the result of the attraction or repulsion between two charged objects.
2. How is electric potential energy related to kinetic energy?
In an electric potential energy/kinetic energy question, the electric potential energy is converted into kinetic energy as an object moves in an electric field. This conversion occurs due to the work done by the electric force on the object, resulting in a change in the object's velocity.
3. How do you calculate electric potential energy?
The electric potential energy of a charged object can be calculated using the equation U = qV, where U is the potential energy in joules, q is the charge of the object in coulombs, and V is the electric potential in volts.
4. What is the difference between positive and negative electric potential energy?
Positive electric potential energy represents a repulsive force between two positively charged objects or an attractive force between a positively charged object and a negatively charged object. Negative electric potential energy represents an attractive force between two negatively charged objects or a repulsive force between a negatively charged object and a positively charged object.
5. How does the magnitude of electric potential energy affect the motion of an object?
The magnitude of electric potential energy affects the kinetic energy and therefore the motion of an object. A higher potential energy will result in a higher kinetic energy and faster motion, while a lower potential energy will result in a lower kinetic energy and slower motion. This relationship is described by the conservation of energy principle.
